Should I Remove Recessed Cans Before Skimcoat And Retexture? - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 09-16-2010, 12:04 AM   #1
Rewards Points: 337
remove recessed cans before skimcoat and retexture?
I had the 22 recessed can lights installed down stairs, remodel cans, lot of holes for running wire had to be cut and a new line was run so I need to retexture. Drywaller said I really need to skimcoat the ceiling and re-do the knockdown. Okay, he did not remove the can lights and skim coated over the entire ceiling. Problem?? I am going to remove the mud from the edge of the cans and tape before texture gets sprayed.
I just thought it would be normal to remove the cans before skimcoat and texture? I guess that would make texturing hard with 22 can fixtures hanging a few inches from the holes??
thanks!
titan7 is offline   Reply With Quote
Old 09-16-2010, 02:12 AM   #2
liscenced electrician
Rewards Points: 538
thanks!
im a little confused as to what you mean. Maybe a picture of what you have now so we can tell you what to do?
jimmy21 is offline   Reply With Quote
Old 09-16-2010, 07:23 AM   #3
DIY staff
Rewards Points: 7,174
Not to many drywall tapers are electricians,too.
It sounds like he taped and mudded in the usual and customary way. Scrape any excess mud from the rims of the cans and finish up the job--Mike---
Old 09-16-2010, 07:53 AM   #4
Rewards Points: 79
Shove a wad of newspaper (inside a plastic bag is best) into the cans. Retexture and remove as you go along before it sets up too hard.
If you don't have time to do it right, when will you ever have time to do it over?
jackofmany is offline   Reply With Quote
Old 09-16-2010, 07:57 AM   #5
You don't remove the cans to texture
Unless they are retrofit cans you can't remove them...easily
You do remove the trim rings
And make sure the area where they seat is clean & flat as you mud
Old 09-16-2010, 01:33 PM   #6
Registered User
Rewards Points: 5,216
As Dave said, remove the trim ring, the can should be flush or slightly recessed. Don't skim the whole ceiling, only over the access patches so the knockdown texture will match evenly. Texture the patches and a little beyond for a good blend. Practice first on extra drywall.
Gary
Old 09-16-2010, 11:00 PM   #7
Rewards Points: 337
Yes they are re-model can lights.
Here is the deal, all the can lights were installed. There were way too many holes cut to run (2) dedicated 20 amp lines to the kitchen and we moved a couple walls so patching that many holes and trying to match texture was not going to work.
My drywaller skimcoated the entire ceiling after patching all the holes. He did not remove the recessed fixtures, but we did take the trim rings off. As he skim coated the ceiling flat, the mud covered the the bottom edges of the recessed cans.
He said removing them would have been a big PITA. The bottom of the cans are 100% flush with the ceiling now, before the skim coat the bottoms were about 1/16" lower than the ceiling.
Any issues with just scaping of the mud on the bottom of the cans and taping off before texture is sprayed? basically if I ever remove the can there will be a ring in the mud the same diameter as the can.
Old 09-17-2010, 03:57 AM   #8
Phoenix
You don't need to remove the cans, just mask & texture & you're fine. The cans are permanant so the ring that would be there if you ever removed them is a non-issue. When the trim ring is in place it will cover all of that & they will look fine.
Axecutioner-B is offline   Reply With Quote
Old 09-20-2010, 12:15 PM   #9
how do you apply refltix inulation to the studs do yo nail it or staple
jjvogtsr is offline   Reply With Quote
Old 09-20-2010, 05:36 PM   #10
Drywall contractor
Rewards Points: 1,070
No, they should not be removed.
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
