#1 |
Should I really level 5 my drywall?
Hi All,
I just recently realized there are different drywall finishes. What are your thoughts on level 5 finishing for basements? I have to say, I hate seeing the slight imperfections in the walls throughout the house, so I may have answered my own question. Now for the level 5, do people really put on mud with a paint roller? As always, thank you!! |
#2 |
Should I really level 5 my drywall? |
| The Following User Says Thank You to Lavid2002 For This Useful Post: | Xygris (01-31-2012) |
#3 |
Lic. Builder/GC/Remodeler
The question is more of:
Does the average DIYer have the skill level and ability (and patience) to perform a level 5 finish on a project?
- Build Well - |
#4 |
Disabled wood vet
I didn't know drywall had so many levels.
#5 |
#6 |
MarginallyQualified
Being from the east coast I thought that the norm for walls was plaster smooth.
Imagine my surprise when I went to the west coast and saw what I took for amateurish work. I still see anything but plaster smooth as a sign of incompetence... not a style choice. Others can have their views too. |
#7 |
Yea, I think I'm sold on the roll on joint compound (level 5 finish) I don't mind some extra work. Thanks guys
#8 | |
paper hanger and painter
Should I really level 5 my drywall?Quote:
good luck, it takes YEARS of practice to do this properly
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
| The Following 2 Users Say Thank You to chrisn For This Useful Post: | AtlanticWBConst. (01-27-2012), framer52 (04-29-2012) |
#9 |
gravity always wins
It depends on how the wall will be finished. If it gets painted with flat finish and the light strikes it straight on or if it gets a more glossy finish and the light will wash across the surface. Light colors and glossy finishes need a higher level of finish than dark flat colors.
#10 |
Seems like overkill for a basement, but it is up to your personal preference. Think about your lighting setup in the basement and if your light patterns will show many imperfections. Generally basements don't have much natural light so you could get away with more. I also hate seeing any imperfections, but I think with a small amount of extra time and attention to detail I could get the walls to a point that would look perfect to the naked eye or at least enough to make me happy. It really depends on lighting. I have seen terrible walls that look great until you put a light at the right angle.
#11 |
Should I really level 5 my drywall?....Good Luck Storming the Castle....
- Build Well - |
#12 |
![]() Any opinions on the mud to use at each step? Should I use the regular green top for everything or should I use the green top and then the blue top (lightweight) for the final level 5 skim coat? |
#13 |
Use the light weight blue top.
- Build Well - |
#14 |
Unless I was trying to cover up a wall full of repairs or an old texture there's no way in heck I would ever go to all that extra work and dust making labor.
100 % not worth the time and little if anything to gain. |
#15 |
Hi,
I am a Professional Drywall Finisher. Level 5 is overkill in my opinion, you can achieve close to the same result with another coat or two of paint (applied properly). The only place I would Level 5 something in my own home is on a wall which is saturated with sunlight at shallow angles, or skylights. It's really not worth the trouble... and for most of you, a poorly done level 4 finish is probably great in your eyes. I wouldn't worry about trying for a level 5 finish, most likely it's far beyond what most of you are capable of (or will ever see). Dan |
| The Following User Says Thank You to dberladyn For This Useful Post: | chrisn (01-28-2012) |
| Display Modes | |
| Drywall ceiling above bathtub/shower | larabiec | Drywall & Plaster | 3 | 06-26-2011 02:23 PM |
| Attach Drywall through plywood | HooKooDooKu | Drywall & Plaster | 2 | 01-20-2010 11:05 PM |
| Framing for Drywall Ceiling | Wino | Building & Construction | 1 | 01-13-2010 03:05 PM |
| Drywall over plaster? | Rob1980 | Drywall & Plaster | 10 | 04-11-2009 06:05 PM |
| Good ways to run pegboard up to drywall? | upthemaiden | Drywall & Plaster | 1 | 03-09-2009 02:12 PM |
