Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Drywall & Plaster
Old 03-08-2011, 02:10 AM   #1
Should I prime the entire wall? Or just go over compound, nails, and tape?
Should I just prime what may leak through? Or do it all?
weedelf is offline   Reply With Quote
Old 03-08-2011, 06:42 AM   #2
JohnnyD44's Avatar
From all of my experiences, anytime I'm painting new drywall I always prime the entire sheet, sometimes twice. A nice coat of primer will make painting alot easier and allow a more even coat. On my new drywall I just put up in the kitchen, I did two coats of primer and then two coats of paint. Perhaps a bit excessive, but it really looks great.
JohnnyD44 is offline   Reply With Quote
The Following User Says Thank You to JohnnyD44 For This Useful Post:
oh'mike (03-08-2011)
Old 03-19-2011, 01:17 AM   #3
Prime everything. Keep in mind that you will need to sand the wall after priming to smooth it prior to painting. The sanding of the paper will raise fuzz that will be "frozen" by the primer makiing it easier to sand off.
Dusty1 is offline   Reply With Quote
The Hows and Whys of Furring Strips. Part-1 Willie T How To Guides 12 03-01-2013 03:58 PM
Best way to temporarily cover an unfinished wall for art hanging? datdere Building & Construction 7 12-17-2009 07:15 AM
Reattaching baseboards? Joony Flooring 7 07-06-2008 09:11 AM
