Shimming For Ceiling Drywall..Where To Start??? - Drywall & Plaster - Page 2 - DIY Chatroom Home Improvement Forum
Old 07-01-2011, 04:53 PM   #16
General Contractor
Around here the sheetrock isn't glued either.....
In the first post is sounded worse than it does now......ah well, carry on.
dsconstructs is offline   Reply With Quote
Old 07-01-2011, 05:02 PM   #17
Tileguy
Bud Cline's Avatar
Rewards Points: 558
We used a lot of channel in Texas and I haven't seen it anywhere here in Nebraska in eighteen years. All drywall gets gued here though.
XXX
Old 07-03-2011, 05:28 PM   #18
Too Old
So how long do you hold the drywall so the glue dries? You have got to be kidding right?
Get the joists to no more then 1/4" (I always use at least an 8' level)Doing a lid you put a couple nails in the sheet to hold it up complete the lid and come back and screw it. That size room would take about 2 hours max screwed and ready for inspection.
havalife is offline   Reply With Quote
Old 07-05-2011, 05:28 PM   #19
Tileguy
Bud Cline's Avatar
Rewards Points: 558
The world is full of shallow thinkers and I'm thinking it is getting worser and worser as time goes on. You have got to be kidding right?
XXX
Old 07-05-2011, 05:34 PM   #20
sounds like a job for the green guy: hold this sheet of 4x10 drywall on the ceiling for approximately two hours while the glue dries, I WILL be back, promise.
chrisBC is offline   Reply With Quote
Old 07-05-2011, 07:29 PM   #21
Too Old
I didn't bring up the glueing drywall to the joist look at post #14 I have never seen it done
Old 07-05-2011, 07:45 PM   #22
I've never done it either or seen it done where I work.
However I do know they do it in some areas, I think what the process is to lay a bead of glue on the joists/studs, then board and screw it off as normal. As far as I know anyways that's the difference.
Funny how things are different in different areas.
The Following User Says Thank You to chrisBC For This Useful Post:
Bud Cline (07-05-2011)
Drywall ceiling above bathtub/shower larabiec Drywall & Plaster 3 06-26-2011 01:23 PM
Drywall - Horizontal or vertical slinku2020 Drywall & Plaster 27 04-08-2010 12:40 PM
Good ways to run pegboard up to drywall? upthemaiden Drywall & Plaster 1 03-09-2009 01:12 PM
Recessed Cans fall right in the middle of my drywall seam... What do i do?? AndyH Building & Construction 20 03-13-2008 07:12 PM
Framing and Drywall questions haysdb Building & Construction 5 11-04-2005 07:11 AM
