Sheets Meeting At Electrical Receptacle - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 05-20-2012, 05:25 PM   #1
Rewards Points: 1,062
Question
sheets meeting at electrical receptacle
is it bad if two sheets meet around an electrical receptacle, e.g. vertically in the middle of it so half the receptacle goes into one and the other half into the other sheet? for finishing purposes? in other words, should you always be trying to aim to locate a receptacle so that is entirely surrounded by only one sheet on all sides?
thanks
Old 05-20-2012, 05:35 PM   #2
DIY staff
Rewards Points: 7,174
Some times that happens---just tape it---you want to keep taper edge to tapered edge--butt to butt--
full sheets around doors and windows--no seams at the corners of windows or doors.--framing in those areas moves a lot--so no joints--
amakarevic (05-20-2012)
Old 05-20-2012, 05:37 PM   #3
but it IS ok to have seams in the middle of one side of a door/window, yes? just not at a corner...
The Following User Says Thank You to amakarevic For This Useful Post:
oh'mike (05-20-2012)
Old 05-20-2012, 05:46 PM   #4
Rewards Points: 87
I've had a joint over the middle of a window in my house. No problems after a year and half on the window. I really try not to do seams around the doors.
As for outlets, it happens frequently for me. I'm not much of a planner. But I've never had a problem there.
myowneq is offline   Reply With Quote
The Following User Says Thank You to myowneq For This Useful Post:
Old 05-20-2012, 07:42 PM   #5
Question
so do you just put a rectangular sheet over the whole door frame opening and then cut out the actual opening while the perimeter is screwed in? because cutting it before hanging could break the thin strips on either side.
Old 05-20-2012, 08:08 PM   #6
Rewards Points: 87
I do cut after I hang. From my own experience, trying to handle a sheet with the thin strip cut already is bad. I've broke every one I tried to do like that. So I use a manual drywall saw and go slow when I have the thin strips.
amakarevic (05-21-2012)
DIY Electrical work in New Jersey electures Electrical 42 12-19-2012 03:19 PM
120/220v electrical receptacle for electric range minsy Electrical 4 01-17-2011 05:54 PM
Electrical box replace,addiitions, city permits and looking for an electrician ramchy Electrical 3 08-02-2009 11:12 AM
Receptacle Rating question Ultrarunner2017 Electrical 19 12-20-2008 06:20 PM
Receptacle Rating question Ultrarunner2017 Electrical 5 12-18-2008 05:36 PM
