Sheetrock In A Window - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 03-26-2011, 08:38 PM   #1
Sheetrock in a window
Is it ok to use sheetrock in a kitchen window above the sink
bebugbee is offline   Reply With Quote
Old 03-26-2011, 09:43 PM   #2
Old School
Willie T's Avatar
Yes, it is.
Willie T
Old 03-27-2011, 07:17 PM   #3
If you have the older aluminum framed windows, they sweat with the cold weather, and can mold and mildew the sheetrock. In that instance you should use a plastic cap that can be put onto the sheetrock that buts up to the window. If you have vinyl framed windows, then you can put the rock right up to it without nearly as much worry about moisture.
redmanblackdog is offline   Reply With Quote
Old 03-30-2011, 07:18 PM   #4
Drywall contractor
Rewards Points: 1,070
I wouldn't recommend it. I'd use wood trim....
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Removing a window for painting... JJDoherty General DIY Discussions 6 08-31-2010 08:39 PM
Defog window recap greenmax General DIY Discussions 4 05-07-2010 05:00 PM
help need to know how to replace windows wrapped in drywall caide3 Carpentry 4 03-02-2010 12:41 PM
Problem with window and everything around it malfunction Building & Construction 3 05-26-2009 05:11 PM
Replace old window with smaller window Suncrest79 Building & Construction 3 04-15-2009 08:39 PM
