-   -   Sheetrock in a window (http://www.diychatroom.com/f101/sheetrock-window-99678/)
bebugbee 03-26-2011 09:38 PM
Is it ok to use sheetrock in a kitchen window above the sink
Willie T 03-26-2011 10:43 PM
Yes, it is.
redmanblackdog 03-27-2011 08:17 PM
If you have the older aluminum framed windows, they sweat with the cold weather, and can mold and mildew the sheetrock. In that instance you should use a plastic cap that can be put onto the sheetrock that buts up to the window. If you have vinyl framed windows, then you can put the rock right up to it without nearly as much worry about moisture.
bjbatlanta 03-30-2011 08:18 PM
I wouldn't recommend it. I'd use wood trim....
