Sheetrock Vs Alternatives - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 05-01-2011, 03:21 PM   #1
Rewards Points: 26
Sheetrock vs alternatives
What sort of questions do you ask yourself or steps do you take when deciding to put up sheetrock vs plaster,etc?
We have a room that is about 1,000 sq ft(so a pretty big room). The walls in general are okay, no big holes or anything like that. But there are literally hundreds of nail holes!
So I am thinking what is the best way, most cost effective way, to take care of them. cost is primary factor. time, quality, etc are important but cost is #1.
Thanks in advance!
actually I also thought about just hiring a drywall company, I heard the labor is relatively cheap because they do it so much faster than I could
peequi is offline   Reply With Quote
Old 05-01-2011, 05:30 PM   #2
Depends what you think is cheap. I really don't want to touch any job for under $400, but really I am too busy and don't want any side work anyways. A good tradesman is worth $40/hr, but you can expect at least $100 minimum per trip.
I would NEVER choose plaster over drywall. I have no idea why plaster is still in use.
dberladyn is offline   Reply With Quote
Old 05-03-2011, 10:58 PM   #3
Rewards Points: 26
I guess what I meant by cheap is, it is probably better for us to pay a professional vs doing it ourselves, taking up valuable time that could be used towards actually running the business. It seems like something like this is usually best to just fork up the bucks.
Old 05-03-2011, 11:46 PM   #4
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
because it looks a lot nicer that sheetrock and mudded joints. If you use rock lath, it is a much sturdier installation as well.
and you don't have to paint it.
insulation types i can use between current and new sheetrock on ceiling philbee62 Remodeling 4 08-05-2010 07:12 PM
Sheetrock And Insulation Question kn1564 Remodeling 4 04-23-2010 11:24 AM
Sheetrock put on w/o removing door trim Carla33 Carpentry 13 12-26-2009 01:32 AM
Using nail Gun on sheetrock jwshome Building & Construction 12 09-08-2009 09:16 PM
Mounting a flatscreen TV on a sheetrock wall TanMan Building & Construction 14 02-16-2009 04:26 PM
