Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Drywall & Plaster
Old 04-29-2011, 09:26 PM   #1
sheetrock install
can you join two non tapered pieces of sheetrock
B howell is offline   Reply With Quote
Old 04-29-2011, 09:28 PM   #2
Framing Contractor
sheetrock install
yes you can, although the joint is more difficult to finish.
sixeightten is offline   Reply With Quote
Old 04-30-2011, 12:46 AM   #3
Moderator
sheetrock install
http://www.finehomebuilding.com/how-...tt-joints.aspx
And, welcome to the forum!
Gary
Clothes taking longer to dry?
Delta-FL on floor and XPS on walls. Should I install the flooring or the walls first? yotaman Remodeling 11 04-19-2011 10:20 AM
New cabinets, subfloor & install height Ohming Building & Construction 10 03-02-2011 03:18 PM
Should I install interior doors before floor? pttcc Flooring 13 11-23-2010 10:02 AM
Anyone install a tin/copper style ceiling? flashme18 Remodeling 7 07-19-2009 08:56 AM
Preparing to install Kerdi on bathtub surround DIY-Renovator Flooring 18 07-17-2008 11:42 AM
