Sheetrock Confusion - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 03-29-2012, 06:15 PM   #1
AWF
Sheetrock confusion
The sheetrock on our bathroom ceiling is different than on the bathroom walls. It doesnt seem to have a paper face but is not fiberglass. The attic side is kind of like textured plastic with raised strands. What is it? It says usg on the attic side
AWF is offline   Reply With Quote
Old 03-29-2012, 06:41 PM   #2
DIY staff
Rewards Points: 7,174
That's a new one on me---how old is it? Any numbers or other identifying marks?
Old 03-29-2012, 07:08 PM   #3
Drywall and Painting Pro
Sir MixAlot's Avatar
Rewards Points: 918
AWF, Can you snap a photo of it?
Sir MixAlot is offline   Reply With Quote
Old 03-29-2012, 07:23 PM   #4
AWF
Date says 8/2002 CEILING SURFACE IS GRAYISH COLOR AND NOT TYPICAL CARDBOARD. HARDER ALMOST LIKE DURAROCK BUT IT IS NOT. ALSO SIZE OF SHEET IS 8 FEET WIDE, 10 FEET LONG WHICH ALSO IS NOT TYPICAL
Old 04-01-2012, 12:13 PM   #5
Drywall contractor
Rewards Points: 1,070
There's got to be a joint somewhere. You couldn't get an 8'x10' sheet in the room, let alone hang it. As far as what it's made of, 'ya got me....
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 04-01-2012, 05:11 PM   #6
AWF
The sheet is exactly what i said it was. You had nothing to contribute why reply.
Old 04-01-2012, 06:13 PM   #7
Rewards Points: 6,652
It is actually the incorrect product for the ceiling. what the OP is talking about, is U.S. Gypsum's Backerboard most likely, which is only to be used for wall tile, or floor tile. http://www.usg.com/flooring/backerboard.html The only thing close with a Gray Acrylic and fiberglass face on the other side, is Georgia Pacific's Denshield, which I used when I laid the tile for my bath floor.
Old 04-01-2012, 06:38 PM   #8
bbo
I thought he was contributing. He replied as he was curious as to the size.
I've never seen 8x10 boards myself, where would one get them? how would you get them in the room?
do you have a pic of the board?
bbo is offline   Reply With Quote
The Following User Says Thank You to bbo For This Useful Post:
gregzoll (04-01-2012)
Old 04-01-2012, 06:47 PM   #9
Drywall contractor
And it doesn't come in 8'x10' sheets! No gypsum (or backerboard) product does.That's why I replied and had something to "contribute". If you're looking from the attic side, you won't see the joint if they hung it parallel to the joists (not the common or best way) rather than across the joists. The joint won't be visible from the attic. I've been in the trade for 38 years. What are your credentials??
Best of luck.
The Following User Says Thank You to bjbatlanta For This Useful Post:
bbo (04-01-2012)
Old 04-01-2012, 06:55 PM   #10
bjb, I reported them for their smart attitude, so they may not be coming back at this point. I would say leave it as a fly-by and lets move on with our lives.
Old 04-01-2012, 06:59 PM   #11
Drywall contractor
Thanks gregzoll, I have no issue with it. He has a right to express his opinion. I just try to help out when I can....
Old 04-01-2012, 07:08 PM   #12
Same here, but attitude does not get you help on a public forum, unless you are expressing that you are stressed because you messed up, and now need venting or help.
Replacing Sheetrock Window Trim with Wood - NEWB Alert - Please Help! Mark79 Remodeling 7 01-24-2012 11:37 AM
insulation types i can use between current and new sheetrock on ceiling philbee62 Remodeling 4 08-05-2010 07:12 PM
Sheetrock put on w/o removing door trim Carla33 Carpentry 13 12-26-2009 01:32 AM
Using nail Gun on sheetrock jwshome Building & Construction 12 09-08-2009 09:16 PM
Mounting a flatscreen TV on a sheetrock wall TanMan Building & Construction 14 02-16-2009 04:26 PM
