Sheetrock Compound & Painting - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 09-27-2012, 06:56 PM   #1
Rewards Points: 121
I seem to have a recurring problem when I try to paint over sheetrock compound. Once it dries, I put on the primer and then apply the latex paint. More times than not, the paint will bubble and basically come right off of the wall in small sheets of dried latex. Any ideas to why this would happen? Sponging on some sodium bicarbonate before applying the primer has been recommended.
Thoughts? Suggestions?
Thanks!
mikeyp78 is offline   Reply With Quote
Old 09-27-2012, 10:05 PM   #2
do you sand it after it dries?
if so do you brush all the sanding dust off the wall?
you may be painting over the dust which is why it peels off so easy. are you letting the primer dry the recommended amount of time? are you using a good primer?
Old 09-29-2012, 10:46 AM   #3
Rewards Points: 121
I sand it. Brush it. I've used Kilz as a primer because it was a bathroom. Does sponging it with a damp sponge do a better job at removing the dust?
Old 09-29-2012, 06:33 PM   #4
paper hanger and painter
chrisn's Avatar
Rewards Points: 228
oil? if not, then you need to get a better primer
The Following User Says Thank You to chrisn For This Useful Post:
mikeyp78 (09-29-2012)
Old 09-29-2012, 07:13 PM   #5
Rewards Points: 121
Any suggestions for a good primer?
Old 09-29-2012, 08:48 PM   #6
Drywall contractor
Rewards Points: 1,070
That's really bizarre! What type of compound are you using?? I've never seen or heard of a problem like you're describing. Dust on the wall won't be a cause. It will just make the prime coat rough where you'll have to sand before final coat. In new construction, I've only seen one painting contractor who ever did any type of "dust removal" before priming. He had his guys use sponge mops to "wipe down" the walls before prime coat. I think the builder only used him on a house or two...
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
The Following User Says Thank You to bjbatlanta For This Useful Post:
Old 09-29-2012, 10:04 PM   #7
Rewards Points: 121
Sheetrock brand - all purpose.
Old 09-29-2012, 10:05 PM   #8
Rewards Points: 121
Could it be the brand of paint? The finish?
Old 09-30-2012, 04:47 AM   #9
chrisn's Avatar
Rewards Points: 228
Zinnsers 123 and paint from a real paint store
Old 09-30-2012, 09:23 AM   #10
Rewards Points: 121
So... stay away from Behr or Valspar, you're saying?
Old 09-30-2012, 09:37 AM   #11
I am trying to paint the corner of a wall but the paint has chipped off and the metal wall is showing how can I fix this
edixon is offline   Reply With Quote
Old 09-30-2012, 01:27 PM   #12
bbo
you might try a new thread for better exposure.
but it sounds like the joint compound has chipped off a metal corner bead.
not just paint.
bbo is offline   Reply With Quote
The Following User Says Thank You to bbo For This Useful Post:
ToolSeeker (10-01-2012)
Old 09-30-2012, 05:32 PM   #13
chrisn's Avatar
Rewards Points: 228
aaahh yes
mikeyp78 (09-30-2012)
Replacing Sheetrock Window Trim with Wood - NEWB Alert - Please Help! Mark79 Remodeling 7 01-24-2012 12:37 PM
Sheetrock Painting Uneven averity Painting 1 01-26-2011 08:08 AM
Painting of green sheetrock in bathroom Jacque Painting 2 10-12-2010 12:46 AM
insulation types i can use between current and new sheetrock on ceiling philbee62 Remodeling 4 08-05-2010 08:12 PM
painting joint compound in a bathroom AnnaVanLenten Painting 5 10-09-2008 11:14 AM
