-   -   Sheetrock Compound & Painting (http://www.diychatroom.com/f101/sheetrock-compound-painting-158188/)
mikeyp78 09-27-2012 05:56 PM
I seem to have a recurring problem when I try to paint over sheetrock compound. Once it dries, I put on the primer and then apply the latex paint. More times than not, the paint will bubble and basically come right off of the wall in small sheets of dried latex. Any ideas to why this would happen? Sponging on some sodium bicarbonate before applying the primer has been recommended.
Thoughts? Suggestions?
Thanks!
DannyT 09-27-2012 09:05 PM
do you sand it after it dries?
if so do you brush all the sanding dust off the wall?
you may be painting over the dust which is why it peels off so easy. are you letting the primer dry the recommended amount of time? are you using a good primer?
mikeyp78 09-29-2012 09:46 AM
I sand it. Brush it. I've used Kilz as a primer because it was a bathroom. Does sponging it with a damp sponge do a better job at removing the dust?
chrisn 09-29-2012 05:33 PM
oil? if not, then you need to get a better primer
mikeyp78 09-29-2012 06:13 PM
Any suggestions for a good primer?
bjbatlanta 09-29-2012 07:48 PM
That's really bizarre! What type of compound are you using?? I've never seen or heard of a problem like you're describing. Dust on the wall won't be a cause. It will just make the prime coat rough where you'll have to sand before final coat. In new construction, I've only seen one painting contractor who ever did any type of "dust removal" before priming. He had his guys use sponge mops to "wipe down" the walls before prime coat. I think the builder only used him on a house or two...
mikeyp78 09-29-2012 09:04 PM
Sheetrock brand - all purpose.
mikeyp78 09-29-2012 09:05 PM
Could it be the brand of paint? The finish?
chrisn 09-30-2012 03:47 AM
Zinnsers 123 and paint from a real paint store
mikeyp78 09-30-2012 08:23 AM
So... stay away from Behr or Valspar, you're saying? :laughing:
edixon 09-30-2012 08:37 AM
I am trying to paint the corner of a wall but the paint has chipped off and the metal wall is showing how can I fix this
bbo 09-30-2012 12:27 PM
you might try a new thread for better exposure.
but it sounds like the joint compound has chipped off a metal corner bead.
not just paint.
chrisn 09-30-2012 04:32 PM
aaahh yes:thumbsup:
