Sheetrock Ceiling Structure - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 11-23-2010, 09:56 PM   #1
sheetrock ceiling structure
we want to put a sheetrock ceiling in a basement where all the heat ducts & plumbing are below the floor joist from the 1st floor. Our room demensions are pretty large so installing wooden beams or joists would lower the ceiling too much. Does anyone make a steel or some other material frame that can be installed that would support the sheet rock weight?
jcc3 is offline   Reply With Quote
Old 11-26-2010, 10:24 AM   #2
Drywall contractor
Rewards Points: 1,070
There are grid systems that can support (and are designed for) the weight of drywall (try USG.com for more info). Unfortunately you still have to allow room for grid clearance (tees are about 1-1/2" tall) and room to tie the hanger wires, so you'd still need to drop 4" minimum.....
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 11-27-2010, 09:53 AM   #3
Drywall and Painting Pro
Sir MixAlot's Avatar
Rewards Points: 896
You could use metal "Hat channel".
Sir MixAlot is offline   Reply With Quote
Old 11-28-2010, 06:24 AM   #4
yup...what he said..
Resiliant channel would do the trick.
williamwiens is offline   Reply With Quote
Paint peeling off Bathroom Ceiling!!! armen30 Painting 17 12-08-2011 08:26 AM
An extensive 'drop ceiling' project- where to begin... kpatten Remodeling 7 02-05-2010 06:31 PM
Sheetrock separation at the ceiling JoJoinVA General DIY Discussions 25 01-21-2010 12:48 PM
Ceiling condensation icemand Building & Construction 1 12-15-2009 05:16 AM
Textured ceiling Sheetrock repair theatretch85 Building & Construction 10 02-25-2009 05:14 PM
