Sheetrock Around Bath Window - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 10-09-2013, 02:59 PM   #1
Rewards Points: 54
Sheetrock around bath window
I assume you use corner bead?
digitalplumber is just a name for use here, I am not a plumber!
digitalplumber is offline   Reply With Quote
Old 10-09-2013, 03:18 PM   #2
Rewards Points: 13,458
You know the deal. Post a picture.
Corner bead for what?
Almost never a great idea to use sheetrock returns.
Far better to build real wood jambs, they hold up far better in a most area, in fact I try to use all vinyl trim in a bathroom.
Sure hope that windows not in the shower area!
Old 10-09-2013, 03:21 PM   #3
Rewards Points: 54
Not in shower, Sheetrock is what it was trimmed in originally. Can't post a pic right now.
Old 10-09-2013, 03:30 PM   #4
If that the way your going to trim it then yes you need outside corner bead.
A far nicer look is rounded corners. It softens the whole look.
Installing a Replacement Vinyl window with brick mold jlatulippe Carpentry 4 06-23-2011 02:05 PM
window performance question renbelle Building & Construction 4 10-06-2010 02:25 PM
Old Bay Window, lack of support... ogrenjr Building & Construction 6 03-04-2010 09:30 PM
help need to know how to replace windows wrapped in drywall caide3 Carpentry 4 03-02-2010 12:41 PM
Moisture on windows baum Building & Construction 56 12-22-2009 05:39 PM
