Sheetrock - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 03-18-2011, 12:07 PM   #1
Sheetrock
Should sheetrock be installed on a ceiling longway with the ceiling joist or across the ceiling joist.
clays02 is offline   Reply With Quote
Old 03-18-2011, 12:13 PM   #2
Experienced
Jackofall1's Avatar
Hi and welcome Clays02, to the best darn DIY'r site on the web.
When doing a ceiling I have always put the long joint parallel with the joist. This method allows for maximum support behind the joint.
Mark
Old 03-18-2011, 12:47 PM   #3
Old School
Willie T's Avatar
http://www.lafargenorthamerica.com/G...%20English.pdf
Check out page #8. Either way is acceptable.
I happen to prefer hanging perpendicular to the joists.
Willie T
Old 03-18-2011, 12:51 PM   #4
Phoenix
I prefer perpendicular as well.
Axecutioner-B is offline   Reply With Quote
Old 03-18-2011, 05:50 PM   #5
Masters in Drywall
MnDrywallRanger's Avatar
Wood framing...I definately go with perpendicular...unless there is a rafter change on the ceiling then I continue across with parallel
Steel stud framing...I go with parallel
MnDrywallRanger is offline   Reply With Quote
Old 03-18-2011, 06:31 PM   #6
Registered User
Rewards Points: 4,912
Depends on the drywall thickness and on center framing spacing.
Using a water-based hand-applied or sprayed texture finish:
For framing spaced 16”o.c.:
½” thick gypsum panel products shall be applied perpendicular to the framing members;
5/8” thick gypsum panel products shall be applied either parallel or perpendicular to the framing members.
For framing spaced 24”o.c.:
5/8” thick panel product shall be applied perpendicular to the framing members.
Page 16, APPENDIX ; http://gypsum.org/pdf/GA-216-2010.html
Gary
insulation types i can use between current and new sheetrock on ceiling philbee62 Remodeling 4 08-05-2010 08:12 PM
Sheetrock put on w/o removing door trim Carla33 Carpentry 13 12-26-2009 02:32 AM
Using nail Gun on sheetrock jwshome Building & Construction 12 09-08-2009 10:16 PM
Mounting a flatscreen TV on a sheetrock wall TanMan Building & Construction 14 02-16-2009 05:26 PM
New medicine cabinet--old plaster and sheetrock help! garyofnyc Remodeling 4 10-31-2008 11:15 PM
