Sheetrock - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 08-12-2012, 09:02 PM   #1
amy212's Avatar
Sheetrock
Had plumbing problem so my dad cut a hole in wall 2 fix when he put it back it did not fit flush u could see where it had been cut.... any ideas how it could b repaired and not b noticeable?
Attachment 55683
Attachment 55683
Attachment 55683
amy212 is offline   Reply With Quote
Old 08-12-2012, 09:03 PM   #2
amy212's Avatar
Old 08-12-2012, 09:03 PM   #3
amy212's Avatar
Here is a pic
Old 08-12-2012, 09:14 PM   #4
Rewards Points: 12,830
http://www.diylife.com/2011/02/22/drywall-repair/
Old 08-12-2012, 09:30 PM   #5
Drywall and Painting Pro
Sir MixAlot's Avatar
Rewards Points: 850
He probably needed to sand it little more and also feather out the mud work wider with a 12" knife. If it's already been painting sanding the area will not work. He'll just need to re mud first, then sand, mud and repeat if needed. Hold a bright light to the side of the repair and that should help you see where the humps or indentions are for mudding or sanding.
Sir MixAlot is online now   Reply With Quote
Tear down old fireplace or sheetrock over? hootsmcgoots Remodeling 4 04-30-2012 10:08 PM
Replacing Sheetrock Window Trim with Wood - NEWB Alert - Please Help! Mark79 Remodeling 7 01-24-2012 12:37 PM
insulation types i can use between current and new sheetrock on ceiling philbee62 Remodeling 4 08-05-2010 08:12 PM
Sheetrock put on w/o removing door trim Carla33 Carpentry 13 12-26-2009 02:32 AM
Mounting a flatscreen TV on a sheetrock wall TanMan Building & Construction 14 02-16-2009 05:26 PM
