Sheet Rock Paper Came Off - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 03-08-2011, 10:43 PM   #1
Sheet rock paper came off
Can I still tape it and texture or do I have to replace the sheet rock ..since it came off smooth ..any help is good help thanx
JEDI RAIN
JEDI RAIN is offline   Reply With Quote
Old 03-09-2011, 05:35 AM   #2
DIY staff
Rewards Points: 7,174
I'd replace that---Looks like two sheets---$10--??? If your time is worth any thing at all--not to mention the primer and mud to skimcoat--you will be money ahead.
To save that,you need to prime the raw paper ($14--gallon)--skim with green top(all purpose) $16-bucket--Top with Blue top (light weight--$14--bucket) -and sand it---($5--sanding sponge)
Your call----Mike---
Old 03-09-2011, 07:40 AM   #3
Old School
Willie T's Avatar
Mike's right as rain. Way too much investment and effort to mess with it.
You can easily get to the screws and you already have a template to cut the holes in the new sheets.
BTW, Mike... You can get Green lid for only $12.28 at Home Depot. 'Sheetrock' brand.
Willie T
Old 03-09-2011, 08:36 AM   #4
DIY staff
My memory is good but very short.
Old 03-09-2011, 09:56 AM   #5
I'm not there for a close up, but it looks like it could be salvaged. Tape,mud, and clean up any other problem areas, then prime and take another look, and then texture.
I wasn't sure if you meant that the face paper came off or wall paper came off. If the face paper of the sheetrock came off then the rock should be replaced. If it is wallpaper that came off then if the paper surface of the rock is in good shape then you can go ahead and tape,prime and texture.
redmanblackdog is offline   Reply With Quote
Sheet rock ceiling in basement and Web Trusses i_syed Building & Construction 3 12-21-2010 08:02 PM
Sheet Rock Over Concrete atmironov Drywall & Plaster 3 08-13-2010 03:17 PM
Back Splash Tile Over Old Sheet Rock? Stcrosby Remodeling 3 01-03-2010 12:46 PM
