Setting Wall Sheetrock Horizontally - Drywall & Plaster - Page 2 - DIY Chatroom Home Improvement Forum
Old 02-01-2012, 05:18 PM   #16
DIY staff
Rewards Points: 7,174
Willie T had a link to fine Home building--simple instructions on making your own---4 days ago?
Look for a post with 'butt boards' in the title
Drywall (Butt Boards) - Drywall - DIY Chatroom - DIY Home Improvement Forum
Old 02-01-2012, 06:32 PM   #17
retired union carpenter
Send a message via Yahoo to coupe
Originally Posted by anesthes View Post
Where can I actually order some? The website doesn't appear to have a checkout, and the price list is blank?
-- Joe
Joe, a box of 20 is $73.00
http://www.thatdrywallguy.com/catalo...licer&x=10&y=6
as always, just my thoughts
good luck....coupe/Larry
take what helps? ignore the rest.
coupe is offline   Reply With Quote
Old 02-01-2012, 09:04 PM   #18
I get mine from East Coast Drywall Tools:
http://eastcoastdrywall.com/index.ph...0bca5102563909
A lot of contractors make their own though using the technique described above. Its good apprentice work I guess...
kwilcox is offline   Reply With Quote
Old 02-01-2012, 09:22 PM   #19
011010100110111101100101
Rewards Points: 160
Your name wouldn't happen to be Kyle would it ?
-- Joe
anesthes is offline   Reply With Quote
Old 02-01-2012, 10:18 PM   #20
Registered User
Rewards Points: 4,910
Aren't all joints running with the studs required to be on framing?
"R702.3.5 Application. Maximum spacing of supports and the size and spacing of fasteners used to attach gypsum board shall comply with Table R702.3.5. Gypsum sheathing shall be attached to exterior walls in accordance with Table R602.3(1). Gypsum board shall be applied at right angles or parallel to framing members. All edges and ends of gypsum board shall occur on the framing members, except those edges and ends that are perpendicular to the framing members. Interior gypsum board shall not be installed where it is directly exposed to the weather or to water. "From: http://publicecodes.citation.com/ico...002_par010.htm
R702.3.2 Wood framing. Wood framing supporting gypsum board shall not be less than 2 inches (51 mm) nominal thickness in the least dimension except that wood furring strips not less than 1-inch-by-2 inch (25 mm by 51 mm) nominal dimension may be used over solid backing or framing spaced not more than 24 inches (610 mm) on center." From: http://publicecodes.citation.com/ico...002_par007.htm (Bold is mine).
Gypsum requires positive attachment to framing.....otherwise it voids the fire warranty.
Anybody know of a different code to use than those, let me know- I could be wrong......thanks.
Gary
Old 02-02-2012, 10:19 AM   #21
I had heard that this requirement meant that you couldn't use rock splicers on walls required by code to be fire resistant such as interior facing garage walls.
Old 02-02-2012, 10:44 AM   #22
Old School
Willie T's Avatar
When anything like this is in question, there is only one authority. That is your own LOCAL Building Department... the people who will be doing your inspections.
Willie T
The Following User Says Thank You to Willie T For This Useful Post:
kwilcox (02-02-2012)
Old 02-04-2012, 11:51 AM   #23
Originally Posted by teeman11 View Post
What if you ceiling is 112 inches? I heard that you should put the extra strip (15-16") in the middle because it's easy to mud those two joints at waist height instead of one down at floor level. Is that correct?
i had the same situation with 8'2'' - 8'3'' walls and after debating on where to put the rip i decided instead to go with 54" drywall.
kid tech is offline   Reply With Quote
Old 02-06-2012, 08:20 AM   #24
I thought about that too but that still leaves me a 4 inch gap, just not sure where's the best spot for that gap.
teeman11 is offline   Reply With Quote
Old 02-06-2012, 11:50 PM   #25
I just did my 12x12 ceiling with 3 12foot sheets of lightweight 1/2 inch. No butt joints woot woot. That new lightweight is great. A 12 foot sheet was lighter than your standard 4x8 5/8
conspikuous is offline   Reply With Quote
Gap between bathtub surround and sheetrock on wall Beerad77 Building & Construction 3 01-03-2012 12:24 AM
Retaining wall problem FMS Landscaping & Lawn Care 6 07-04-2011 07:42 PM
Avoiding load on inner, exterior wall jklingel Building & Construction 2 06-04-2011 02:35 PM
Building a half wall: 2 questions kbizzle Carpentry 7 02-19-2011 09:22 AM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 10:47 AM
