Setting Wall Sheetrock Horizontally - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 01-17-2012, 10:02 PM   #1
Rewards Points: 1,062
Question
setting wall sheetrock horizontally
if i am setting my sheetrock horizontally instead of vertically (i.e. panels of 48" height stacked atop one another), since my ceiling height is >96", does there have to be a horizontal 2x4 connector in between the studs where two sheets meet, kind of like equivalent to how it is with vertical studs?
thanks
Old 01-17-2012, 10:11 PM   #2
Disabled wood vet
titanoman's Avatar
Rewards Points: 1,004
No. You don't need blocking where they meet in the middle.
And it is pretty standard to run your sheets horizontal.
Hold the top sheet tight to the ceiling, and then the bottom sheet tight to that one, with the gap at the floor.
titanoman is offline   Reply With Quote
The Following User Says Thank You to titanoman For This Useful Post:
amakarevic (01-17-2012)
Old 01-17-2012, 10:13 PM   #3
sweet. thanks dude
Old 01-17-2012, 10:14 PM   #4
Rewards Points: 13,468
You did install the cieling with 5/8 rock first, right? And always set the top piece first, make sure the seams land in the middle of a stud, When installing the second row do not have the vertcal seams line with the piece above.
Old 01-17-2012, 10:26 PM   #5
got that, chief
Old 01-18-2012, 12:12 AM   #6
Rewards Points: 2,212
we mostly use 1/2" ceiling sheetrock here, it has fibres in it for ceiling application.
mae-ling is offline   Reply With Quote
Old 01-18-2012, 09:11 AM   #7
DIY staff
Rewards Points: 7,174
Ceiling codes vary---here 1/2 " is fine--check the local codes.
Old 01-18-2012, 11:11 AM   #8
I know it was said .. but just reaffirming.. "stagger the joints" so you don't have 8 or 12 foot butt joints. easier to tape and mud properly if boarded properly.
LR
luckyrabbit is offline   Reply With Quote
Old 01-30-2012, 06:23 PM   #9
What if you ceiling is 112 inches? I heard that you should put the extra strip (15-16") in the middle because it's easy to mud those two joints at waist height instead of one down at floor level. Is that correct?
teeman11 is offline   Reply With Quote
Old 01-30-2012, 06:36 PM   #10
That would leave an untapered edge in the middle of the wall, a big no no.
It will show when finished.
Old 01-30-2012, 08:51 PM   #11
Registered User
Rewards Points: 5,498
I've seen/done it both ways. Easier to finish when the joints are directly in front of you. Course, age may have something to do with it.....
A few pro drywall members here, they should check-in sooner or later.......
Just be sure to air seal the cavities behind the insulation first. Then air seal the drywall: http://www.buildingscience.com/docum...wall-approach/
Especially if you have fiberglass cavity insulation.
Gary
Old 01-31-2012, 09:10 PM   #12
I always use these and never land a vertical seam on a stud:
http://www.ezbacker.com/rock_splicer.html
kwilcox is offline   Reply With Quote
Old 02-01-2012, 12:53 PM   #13
011010100110111101100101
Rewards Points: 160
No problems with wall insulation pushing against it?
-- Joe
anesthes is offline   Reply With Quote
Old 02-01-2012, 12:56 PM   #14
Never had any. The joint is really strong.
Old 02-01-2012, 01:13 PM   #15
Rewards Points: 160
Where can I actually order some? The website doesn't appear to have a checkout, and the price list is blank?
-- Joe
Gap between bathtub surround and sheetrock on wall Beerad77 Building & Construction 3 01-02-2012 11:24 PM
Retaining wall problem FMS Landscaping & Lawn Care 6 07-04-2011 06:42 PM
Avoiding load on inner, exterior wall jklingel Building & Construction 2 06-04-2011 01:35 PM
Building a half wall: 2 questions kbizzle Carpentry 7 02-19-2011 08:22 AM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 09:47 AM
