Setting Type Joint Compound Ready To Paint In 90 Minutes - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 05-05-2013, 06:28 AM   #1
Rewards Points: 452
setting type joint compound ready to paint in 90 minutes
http://www.homedepot.com/p/Rapid-Set...2#.UYY0xbU3uHc
This product says it's a 20 minute compound, and ready to paint in 90 minutes.
are all setting type compounds ready to paint in 2 hours?
pman6 is offline   Reply With Quote
Old 05-05-2013, 07:07 AM   #2
Too Short? Cut it Again!
I do not know this brand but you can buy hot mud by the curing times (do realize the curing starts the second you add moisture so allow for time to mix). They start at 5 minute and go up to 120 minute---5, 20, 45, 60, 90 and 120---for example. Not all places will carry all but 5, 20, 45, 90 are pretty common. If you have not used it before, you may find 45 a good starting point. Mix in small batches---like a drywall pan full at a time unless you are taping and can work with part of a bucket full before it sets up.
5 minute is wonderful stuff if you can work really fast or have a helper mixing mud for you. 5 minute sets up near instantly. Its advantage is you can sand and prime it in just a few minutes. I had it on hand for quick, small patches but usually used 20 or 45.
Anyhow, your other question as to how soon you paint what you are consideing will depend somewhat on how thick you are using it. A skim coat of 20 or 45 should certainly be ready to sand and prime in a couple hours, or closer to the cure time for that matter, unless you have deep patching going on. It will most certainly dry faster than pre-mix mud and you can control the consistency.
Dry mud is a little harder to sand so you want to be sure to scrape off excess as much as you can.
Pre-mix mud is still a better choice for large taping jobs just because it is more convenient and you do not have to race it curing on you. Again, if you have someone helping you and use a hot mud with slower cure time it may work for you too. If you really cannot wait out pre-mix drying hot mud is your only other option.
Buy an airtight Rubbermaid type container to store leftover powder.
Old 05-05-2013, 08:57 AM   #3
Rewards Points: 5,974
I agree with SDS. The one mistake people make is when the mud starts to get thick they add more water. If you mix it too thin it will lose it's strength. And you must clean your tools and pan between batches. This is called setting or hot mud,as opposed to drying mud, because it sets by a chemical reaction.
and as SDS said once water hits it this reaction starts and can't be stopped. The reason to clean between batches is any thing left on the tools or in the pan will greatly accelerate the process, as will mixing it with hot water. That ends HOT MUD 101
I have never used or heard of the product you showed so I really can't comment on it.
Old 05-06-2013, 04:08 PM   #4
Rewards Points: 243
Just because hot mud has set up doesn't mean it still doesn't have moisture in it that needs to evaporate. Might cause adhesion problems. I suggest waiting until the next day. It would be a shame to have the paint peel off after all that tedious work painting just to save waiting overnight.
chemman is offline   Reply With Quote
The Following User Says Thank You to chemman For This Useful Post:
oh'mike (05-08-2013)
Old 05-06-2013, 04:17 PM   #5
You are absolutely correct and I should have mentioned it. Just because it's hard does not mean it is dry.
Old 05-08-2013, 05:17 AM   #6
Rewards Points: 452
well, I have some fake 1960's wood panels to remove from the drywall.
hopefully I can skim coat over the glue residue with 90 minute compound and primer the same day.
Old 05-08-2013, 07:27 AM   #7
DIY staff
Rewards Points: 7,174
You will be pushing the job to fast----
If you are skim coating over dry adhesive--I would use the 90 minute for the first coat (or two) the top with Easy Sand----wait until that is dry--then sand and prime---
90 minute mud is hard to sand---
will waiting one day for the mud to dry cause you a problem?
ToolSeeker (05-08-2013)
Old 05-08-2013, 09:01 AM   #8
Since your doing a skim coat it is thin and will not take that long to dry. Just skim it with regular mud easier to work with and easier to sand.
Old 05-08-2013, 05:47 PM   #9
paper hanger and painter
chrisn's Avatar
Rewards Points: 228
[QUOTE=pman6;1172784]http://www.homedepot.com/p/Rapid-Set...2#.UYY0xbU3uHc
are all setting type compounds ready to paint in 2 hours?[/QUOTE]
no
Old 05-09-2013, 02:09 AM   #10
Rewards Points: 452
yeah, I was planning to use easy sand 90 only.
Old 05-09-2013, 09:42 AM   #11
I've found that even the 20 minute stays a bit moist for hours. You can tell by the grayish color that eventually turns white when it's dry.
I mix it with as little water as possible and this still happens.
A tip, for small patches mix it in a ziplock bag, this allows you to kneed it really well and it's easy to clean.
Amilsmithly is offline   Reply With Quote
Old 05-09-2013, 11:24 AM   #12
It's weird that you have to add water to "setting" compound. I just bought a bag of the 90 minute easy sand and it says "low shrinkage" meaning it shrinks. I wonder if I should prime the drywall and the other substrates I'm using it on so the water will evaporate more into the air instead of being absorbed into building materials and causing cracking rather than sinking. Sinking can be fixed more easily with another coat.
Dorado is offline   Reply With Quote
Old 05-09-2013, 06:21 PM   #13
Rewards Points: 452
I have read instructions that say to put primer before skim coats.
I'm going to bring a fan for faster drying.
Old 05-11-2013, 07:45 AM   #14
Setting mud dries by chemical reaction vs drying mud that dries by evaporation setting mud is used because it gets hard and you can put a second coat on without it being dry. This is so you can put a couple coats on in one day and save trips to the site. But yes leave it over night before you prime and paint. A lot of people get bubbles and peeling paint by not letting it dry. And fans will do no good because once the top has set the air can't get to it anyway.
Old 05-20-2013, 08:11 PM   #15
Drywall contractor
Rewards Points: 1,070
You CAN paint in the time frame you're talking about, but I would highly recommend against it. Setting compound often leaves more imperfections than ready-mix. I would recommend a skim with regular ready-mix prior to paint....
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
premix joint compound vs setting type ITE Drywall & Plaster 32 03-12-2014 05:04 PM
Scrape Cracks, Compound, Sand, Paint. Question about the sanding step. Mathlete Painting 18 08-19-2012 05:15 PM
Does all purpose joint compound stick to semigloss ceiling paint in kitchen or bathroom? ziki Kitchen & Bath Remodeling 2 07-24-2010 12:13 PM
Joint compound? Spackle? Or something else? Amycat Painting 15 06-23-2010 09:16 AM
How to deal with setting drywall compound? KUIPORNG Remodeling 11 01-11-2007 09:22 AM
