Setting Type Compound Stick To Paint? - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 03-09-2013, 12:11 PM   #1
Rewards Points: 452
setting type compound stick to paint?
Does setting type joint compound stick to paint the same way vinyl-based joint compound does?
I am going to repair holes in the wall and the wall is already painted, and I need something that dries quick and is ready to paint quick
pman6 is offline   Reply With Quote
Old 03-09-2013, 12:54 PM   #2
DIY staff
Rewards Points: 7,174
You need to define 'setting compound' I use green lid 'multi purpose' for setting the paper because it contains glue and bonds the tape to the wall board.
Powdered easy sand---this is the fast setting compound is not the best for embedding paper tape---however it will stick to painted surfaces well if the paint is lightly sanded first.
Old 03-10-2013, 09:58 AM   #3
Rewards Points: 5,974
Mike green lid all purpose is a drying compound not setting. The setting compounds have a rough enough texture I rarely sand fist. But hey it never hurts to rough it up a little.
As far as painting quick let me add one thing. After patching with the setting mud you need to make your final coat with a drying mud. The chemicals in the setting mud seem too be causing problems with some paints.
premix joint compound vs setting type ITE Drywall & Plaster 32 03-12-2014 04:04 PM
Flat over Semi-Gloss dankreboot Painting 21 02-24-2013 07:46 PM
Paint Stick TRACKER Painting 3 12-10-2010 10:34 PM
Semi gloss on Semi gloss mattpricemn Painting 6 08-25-2008 07:18 PM
How to deal with setting drywall compound? KUIPORNG Remodeling 11 01-11-2007 08:22 AM
