Selecting A Drywall Contractor - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 03-27-2013, 09:15 AM   #1
Rewards Points: 119
Selecting a Drywall Contractor
I am just about ready for drywall in my basement. What are some questions I should ask when they come to quote?
KStatefan is offline   Reply With Quote
Old 03-27-2013, 09:22 AM   #2
Rewards Points: 13,960
Referances and follow up on them, go look at the job or at least call and talk to the past customer.
Licence, insurance, If there going to prime after finish so you can find all the flaws before final payment.
Old 03-27-2013, 09:25 AM   #3
Rewards Points: 119
Thanks.
Do most drywall contractors apply the primer?
Old 03-27-2013, 09:41 AM   #4
No just some.
Mine get paid 1/2 when it's all hung and the balance after it's primed and all repairs and touch up has been done.
Near imposable to get a 100% perfect job and once the primer goes on the flaws will show up.
I've found lots of missed sanding spots loose tape, messed up inside corners, seam lines showing once the primer went on.
Once they get all there money good luck getting them back to do the touch ups.
Old 03-28-2013, 10:44 AM   #5
Rewards Points: 5,974
I don't know many that will do the primer, most just use a bright light. Then the primer goes to the painter. And I agree don't just ask for references check them. Ask friends and neighbors if they know anything about them or if they know someone who has had work done. Check with Better Business, not that stupid Angies List.
Mold behind cabinets, no drywall above ak76 Building & Construction 1 10-13-2012 09:52 AM
Choosing a contractor Grumpy Remodeling 7 04-28-2011 07:29 AM
HELP! Contractor returns in AM! Uneven shelf - how to fix during drywall finish?? MrBoost Drywall & Plaster 6 04-08-2010 01:18 PM
Problem Patching Large Drywall Hole FuLLTiLT Drywall & Plaster 5 11-21-2009 09:42 PM
