Second Coat Mud Question - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 05-13-2013, 09:55 AM   #1
Rewards Points: 85
second coat mud question
Hi all. Newbie at taping/mudding. Have the first coat up. For second coat, I know I put a thin layer to cover the tape. Should I still be able to see the tape after the second coat?
joshs is offline   Reply With Quote
Old 05-13-2013, 10:29 AM   #2
Rewards Points: 528
Josh. keep putting layers of mud on untill when you sand you have a nice smooth fin9sh that meets your approval. We can tell you how we do it, but remember most of us giving you advice have several years of putting it on. just keep mudding and sanding between coats until you are satisfied.
framer52 is offline   Reply With Quote
Old 05-13-2013, 10:38 AM   #3
Rewards Points: 85
I've been trying to keep the coats as thin as possible. Trying to keep sanding to a minimum. Guess I'll go with my dad's mantra. Drywall mudding is never finished, just good enough :-)
Old 05-13-2013, 05:51 PM   #4
Rewards Points: 512
i would never sand between coats. just knock off the ridges with your knife before doing another coat. once the mud is dry you shouldn't see paper on your flats and butts. do as many coats as it takes.
princelake is offline   Reply With Quote
Old 05-13-2013, 06:55 PM   #5
Rewards Points: 6,034
And yes it's normal to see the tape after 2nd coat. And as stated thin is better.
Old 05-15-2013, 08:51 PM   #6
automated tool pro
Rewards Points: 152
ahh to determine what is a coat of mud.....
.........do you consider tape coat the 1st coat or is the first coat actually the first coat you put on after the tape....?
fail/bail/ just answers the question.......tape coat, first coat, second coat, skim coat and sand, brother. you'll still be able to see an impression after the first coat....in most cases.... be careful and NOT try and sand that impression out. Sand after the second then skim tightly. sand again.
drywallfinisher is offline   Reply With Quote
Old 05-16-2013, 12:26 PM   #7
Rewards Points: 85
Sorry. Still learning the lingo. I meant first coat after taping :-)
Thanks!
Old 05-16-2013, 12:58 PM   #8
www.inspectorzo.com
Send a message via Skype™ to InspectorZo
Talking
Thanks!
Josh,
You're doing great! Drywall taping is at best an imperfect finish. That is why it is often textured. Depending on direction of the sheets, the sunlight coming in at different times of the day, overhead lighting, etc. imperfections will become more apparent.
Don't make drywall taping the battleground for perfectionism. If you don't like the way it came out, add a light orange peel texture and it'll all go away.
Good luck!
InspectorZo
Nailing problems and building solutions.
Facebook | Twitter
InspectorZo is offline   Reply With Quote
old style plaster question: base coat diy888 Building & Construction 7 11-29-2011 08:31 AM
partial second coat - did I mess up? matt_ Painting 5 09-22-2009 06:17 PM
Is one coat of stain enough? hayzen Painting 8 09-03-2009 10:13 PM
Can you put brown coat on if it's going to rain? Not Sure Building & Construction 3 03-23-2009 06:57 AM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 08:19 AM
