Seams Are Visible - Possible To Re-mud And Re-tape After The Walls Are Painted? - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 10-04-2013, 04:09 PM   #1
Rewards Points: 578
Seams are visible - possible to re-mud and re-tape after the walls are painted?
Now that my trailer is not specifically for me anymore, and is destined to be a rental, my mom is concerned that some of the mud lines in the master bedroom are visible. For this room we used paper tape and it was the learning curve, so some of the seams are a little jacked up.
We used mesh tape in the living room and are having much better luck, so i have a question.
The room is already painted. Is it possible to remove the tape and redo the seam using mesh tape and fresh mud? Will the mud stick to the painted drywall?
I used Olympic semi-gloss in Grey Marble, three coats, no primer. I know the popular opinion on mesh tape, but i prefer it over paper.
Come and see the progress on my mobile home paradise!!! (NEW PICS ADDED ON 01/26/15!!)
http://www.diychatroom.com/f49/compl...emodel-168570/
TrailerParadise is offline   Reply With Quote
Old 10-04-2013, 04:41 PM   #2
paper hanger and painter
chrisn's Avatar
Rewards Points: 224
the short answer is yes
Old 10-04-2013, 05:05 PM   #3
dannyoung85's Avatar
You could probably save yourself a lot of time and headache if you sprayed the walls with knockdown texture. Depending on how bad the tape joints look now, the knockdown will cover a lot of imperfections.
dannyoung85 is offline   Reply With Quote
Old 10-04-2013, 07:43 PM   #4
Rewards Points: 5,974
No need to remove and re-tape just sand down the high joint and re-mud. And be sure to feather it out farther.
The Following 2 Users Say Thank You to ToolSeeker For This Useful Post:
oh'mike (10-04-2013), Oso954 (10-05-2013)
Old 10-05-2013, 04:37 AM   #5
Rewards Points: 4,792
What ToolSeeker said.
jeffnc is offline   Reply With Quote
The Following User Says Thank You to jeffnc For This Useful Post:
ToolSeeker (10-05-2013)
Old 10-07-2013, 09:10 AM   #6
Rewards Points: 578
Thanks but the issue is the tape not sticking to the wall, its coming up and therefore visible. We removed it this weekend and retaped. So far so good, i guess time will tell.
