Seam Support Crossbar In Ceiling Drywall Repair - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 07-12-2014, 02:28 PM   #1
Rewards Points: 1,062
seam support crossbar in ceiling drywall repair
Consider this repair joint/seam. When there is a joint line that goes perpendicular to the ceiling beams, do I need to insert a support 2x4 crossbar between the beams along where the seam is going to be? I was thinking maybe it would be a good idea for extra support so that it doesn't sag in the future where the seam is supported only by tape. But then again, there isn't much heavy load on it so maybe it's an overkill. Help me decide.
seam support crossbar in ceiling drywall repair-forumrunner_20140712_152757.jpg
Old 07-12-2014, 03:41 PM   #2
Rewards Points: 14,026
Drywall seams should never be unsupported.
Need to have far straighter cuts then that.
Old 07-12-2014, 03:47 PM   #3
Of course, this is not the final cut... So it's fine like this, you're saying, with support (+ straightening the line)?
1/2 inch drywall on the ceiling as long as there is support? forcedreno2012 Drywall & Plaster 14 12-31-2012 07:04 AM
Drywall repair REXAMUS Drywall & Plaster 7 12-21-2011 03:24 AM
drywall ceiling repair after bathroom fire help nilewaves Drywall & Plaster 9 06-07-2011 03:33 PM
Ceiling Support for Drywall joeysmalls Drywall & Plaster 1 06-26-2009 09:05 PM
Drywall thickness on ceiling question. Doug Crf Building & Construction 3 08-28-2006 05:47 AM
