Sealing Off A Problem Spot - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 08-13-2012, 03:42 PM   #1
Sealing off a problem spot
My neighbour who lives in the apartment bellow me is a smoker. My kitchen often smells like an ashtray. Behind my stove is where most of the cigarette smoke is rising into my apartment. The wall is left open there for easy access to the water on/off valve.
Any suggestions on how to seal off or insulate this area to stop my neighbour's smoke from seeping up?
Thanks for any suggestions.
DDL78 is offline   Reply With Quote
Old 08-13-2012, 04:48 PM   #2
Rewards Points: 13,456
What does that cable go to?
Old 08-13-2012, 04:49 PM   #3
That cable is the power cord for the stove.
Old 08-13-2012, 05:34 PM   #4
Is it hard wired to the stove?
There's a simple fix if you or someone got rid of that set up and installed a range plug at the bottom of the wall and a cord on the stove.
Then you could just use a piece of plywood to cover the hole with screws.
May want to also stuff some insulation in the hole around the pipes.
Old 08-14-2012, 01:22 PM   #5
Thanks for the advice Joe.
The power cord is hardwired to the stove. Not sure how much it would cost for me to get an electrician over here to install a range plug, but since I'll only be at this apartment for about 2 years longer, I'm not sure if it would be worth the cost.
I'm gonna do what you suggested. I'll get some insulation and stuff it in along the pipes, and then cover the hole in the wall with a sheet of plywood. I'll probably just cut a little notch out of the top-right corner of the plywood to allow the power cable through.
Old 08-14-2012, 08:41 PM   #6
Rewards Points: 236
thats what you do. and put some weather strip on the plywood.
Fix'n it is offline   Reply With Quote
Problem with toilet (vent problem?) branch155 Plumbing 24 03-09-2012 09:37 AM
much hotter spot on floor BlueBSH Building & Construction 8 06-20-2011 10:08 PM
75 year chimney leak problem mstanleyg Building & Construction 10 03-30-2010 12:38 PM
Stymied by window leakage problem. Matth3w General DIY Discussions 5 06-11-2008 06:26 PM
Post-Tension Slab Problem Advice/Help Mike McBride Building & Construction 2 01-09-2007 01:51 PM
