Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Drywall & Plaster
Old 06-15-2011, 01:55 PM   #1
CNMDESIGN.COM
Screws popping in drywall
What is the main cause for screws popping in drywall?
What can be done to lessen the possibility of this happening?
CNM Design is offline   Reply With Quote
Old 06-15-2011, 03:53 PM   #2
Either setting them too tight (they shouldn't tear through the paper)
or
Not having your studs(etc) flush with each other - not having a flat plane to mount to.
Nick DIY is offline   Reply With Quote
The Following User Says Thank You to Nick DIY For This Useful Post:
CNM Design (06-15-2011)
Old 06-15-2011, 04:09 PM   #3
CNMDESIGN.COM
Sorry
I ment after they are painted. What makes the plaster fall off the screw head a year or two later?
Is it the same thing?
Old 06-15-2011, 04:11 PM   #4
Old School
Willie T's Avatar
Sometimes some of the screws seem to have a factory coating on them that repels plaster or paint.
Willie T
The Following User Says Thank You to Willie T For This Useful Post:
Old 06-17-2011, 06:00 AM   #5
sdsester's Avatar
As lumber contracts and expands with temp and humidity changes, or if it is new construction and the wood was not completely dried before screwing or nailing the drywall, the associated forces from contraction and expansion can cause pops.
sdsester is offline   Reply With Quote
The Following User Says Thank You to sdsester For This Useful Post:
CNM Design (06-17-2011)
Old 06-20-2011, 12:02 AM   #6
Moderator
Some late-night reading: http://docs.google.com/viewer?a=v&q=...711HulsBKUaB2g
http://www.paintsource.net/pages/sol...ood_shrink.htm
http://www.paintsource.net/pages/sol...erfections.htm
Gary
Clothes taking longer to dry?
The Following User Says Thank You to Gary in WA For This Useful Post:
CNM Design (06-20-2011)
Old 06-23-2011, 11:20 PM   #7
Drywall contractor
To lessen the possibility of screws and/or nail "pops", always use adhesive........
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
drywall for vaulted ceiling mdudu Roofing 5 03-02-2010 01:24 AM
Attach Drywall through plywood HooKooDooKu Drywall & Plaster 2 01-20-2010 11:05 PM
Framing for drywall under Spiral staircase clemon03 Drywall & Plaster 6 07-17-2009 04:49 PM
Ecorock (new green drywall product) Sir MixAlot Drywall & Plaster 0 06-20-2009 09:40 AM
Good ways to run pegboard up to drywall? upthemaiden Drywall & Plaster 1 03-09-2009 02:12 PM
