Screws For Plastered Walls - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 12-26-2011, 10:52 PM   #1
Rewards Points: 208
Screws for Plastered Walls
i have plastered walls in my house. what type and size of screws should i use for those coaxial cable wall plates?
http://www.amazon.com/gp/product/B00...WHQW76NDGQQP2C
Scully is offline   Reply With Quote
Old 12-27-2011, 11:28 AM   #2
retired union carpenter
Send a message via Yahoo to coupe
you don't need any special screws for this, you can probably get items cheaer at your local hardware store?
the cable is the hardest thing to run in plaster walls, with plaster running out behind lathing boards and insulation if any?
you need, an old work receptical box, and two Madison bars. cut your hole to fit the box only 2x3"? leaving the top and bottom flanges out of wall, insert box, and fasten with Madison bars. the screws come with the wall plate.
as always, just my thoughts
good luck....coupe/Larry
take what helps? ignore the rest.
coupe is offline   Reply With Quote
Old 12-29-2011, 11:20 PM   #3
Rewards Points: 208
ack...i used sheet metal screws and they didn't work that well. do i need to use wall anchors?
Old 12-31-2011, 08:26 AM   #4
sleepyg's Avatar
Rewards Points: 8
I would think drywall screws would be the best to use. Get those that have finner thread so that yo have more contact area.
sleepyg is offline   Reply With Quote
Old 12-31-2011, 09:24 AM   #5
Rewards Points: 324
I have tried just using screws - but they eventually pull out. I recommend plastic anchors.
tribe_fan is offline   Reply With Quote
Old 12-31-2011, 09:31 AM   #6
Rewards Points: 208
should i use hollow wall anchors?
Old 12-31-2011, 04:27 PM   #7
plaster, is simply just too brittle for any kind of screw. as the screw goes in, it pulverises the plaster into powder.
unless you are lucky enough? to have the old wooden lathing behind your plaster, you might get lucky and screw into the wooden lath with longer screws. if not? you're going to have to use some kind of expansion anchor. the plastic ones might work? if you can drill a good smooth hole in plaster?
I'd cut the head off the plastic anchor, and try to get end of anchor slightly below the surface of plaster in order to get the wall plate in tight to the wall. those heads seem to stick out a bit!
Looking for a step by step for framing basement walls/2x4's wrong direction/stairs??? xray328 Remodeling 27 06-19-2011 09:50 PM
Delta-FL on floor and XPS on walls. Should I install the flooring or the walls first? yotaman Remodeling 11 04-19-2011 10:20 AM
How bad are unencapsulated knee walls? deerhunter Building & Construction 0 11-02-2010 10:41 PM
Basement Walls - Which Paint?Drylok? HandyFrank Building & Construction 3 10-17-2010 01:07 PM
removing concrete parging from basement foundation walls. newzev Remodeling 1 07-24-2009 09:17 AM
