Screw Will Not Go Into Interior Wall - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 12-18-2012, 09:57 PM   #1
Rewards Points: 18
Screw will not go into interior wall
I am trying to hang up closets organizers for a walk in closet and I could not put a screw into the wall. I tried on 4 spots and it would not go into the wall at all.
I used a magnetic studfinder and i could hardly sense nails.
Here is a picture of the wall after I" removed the cable plug.
http://imageshack.us/photo/my-images/706/photo1idn.jpg/
BelgianBillie is offline   Reply With Quote
Old 12-18-2012, 11:01 PM   #2
Rewards Points: 13,472
Use a real stud finder not the one your trying to use.
Looks like you have plaster or plaster board.
Going to have to use a masonery dill bit and may even need a hammer drill to predrill the holes.
What are you trying to drive the screw with?
Old 12-18-2012, 11:05 PM   #3
DIY staff
Rewards Points: 7,174
Yep--real plaster----use a masonry bit and maybe a hammer drill---
Old 12-18-2012, 11:39 PM   #4
Rewards Points: 18
I was able to drill through easily with my driver and drillbit and predrilled the holes. I should get a real stud finder.
Old 12-19-2012, 07:02 PM   #5
Rewards Points: 744
If the other pics on that imageshack link are yours, then you have a very cool house!
Seattle2k is offline   Reply With Quote
Old 12-20-2012, 10:32 AM   #6
Rewards Points: 18
why thank you!
house has a lot of potential for expansion. Though, some defects also which are costing money to fix. Never is ever perfect
What type of nails/screws should be used with furring strips? firsttimeremode Building & Construction 18 10-02-2012 08:30 AM
Help with Screw sizes needed! andyroo77 Building & Construction 5 06-02-2010 09:00 PM
stripped shower screw betsylwhs General DIY Discussions 2 12-28-2009 08:33 PM
screw type bulbs. mpj111 Electrical 5 01-27-2009 03:27 PM
Screw and plug 5/4" PTP decking Klaus Building & Construction 3 06-10-2008 07:01 AM
