Screw Length Recommendations - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 03-13-2010, 07:39 PM   #1
Perhaps I should have asked this question before I started. What is the recommended screw length for 1/2" and 5/8" drywall for walls? How about the spacing between screws? I have put numerous 1/2" sheets up using 1 1/4" screws, will this be a problem?
flati is offline   Reply With Quote
Old 03-13-2010, 09:39 PM   #2
Registered User
Rewards Points: 526
Screw length, spacing, prime before and after texture, floating corners and ceilings, etc.: http://www.gypsum.org/pdf/GA-216-07.pdf
Be safe, Gary
The Following User Says Thank You to Gary in WA For This Useful Post:
flati (03-14-2010)
Old 03-14-2010, 05:10 PM   #3
Thank you Gary!
Old 03-15-2010, 09:49 PM   #4
Registered User
Rewards Points: 526
You're welcome. That is one of those sites you can re-read many times and still learn something new. I know I do, and you can teach an old dog new tricks!
Be safe, Gary
Old 11-07-2010, 07:58 PM   #5
This link isn't working now. What screw length should I use for 1/2" drywall walls? Been using 1 1/4", are 1" acceptable?
Old 11-07-2010, 09:40 PM   #6
Phoenix
I would stick with the 1 1/4's pesonally. I also wouldn't hesitate to use 1 1/4's for 1/2 or 5/8 sheetrock.
Axecutioner-B is offline   Reply With Quote
Old 11-07-2010, 11:34 PM   #7
Registered User
Rewards Points: 526
Yep, 1-1/8 min.: new link- enjoy!
http://gypsum.org/pdf/GA-216-2010.html
Gary
Old 11-08-2010, 01:28 AM   #8
Thank you guys again!
Stuck Screw IceTreay General DIY Discussions 11 09-09-2010 01:56 PM
Swapping old 3ways with new (different screw color configuration on new switch) Michblaze02 Electrical 10 11-08-2009 02:17 PM
Can't get set screw in TP holder loose janralix Plumbing 4 08-12-2009 10:47 PM
gas line vs screw wobblybowl Plumbing 5 05-27-2009 10:49 PM
Hardwood Length...preference? JDeFuria Flooring 3 03-10-2009 05:38 PM
