Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Drywall & Plaster
Old 05-25-2009, 09:45 PM   #1
Sanding new drywall after pimer
I have just applied a good PVA primer coat over new drywall. I removed all drywall dust. The areas of compound are much smoother than the bare drywall papaer face. Do i need to sand all the walls before 2 top coats of latex eggshell paint? Will a textured (3/8" nap) roller cover the differences?
zigmon is offline   Reply With Quote
Old 05-25-2009, 09:50 PM   #2
yummy mummy's Avatar
I thought the same thing when I primed my drywall, but now that I have applied two coats of paint, it looks just fine. The 3/8" nap roller will work good.
You wont be able to tell the difference. Don't sand the paper, or then you will be able to tell the difference......
Good luck.
yummy mummy is offline   Reply With Quote
Old 05-26-2009, 05:27 AM   #3
paper hanger and painter
chrisn's Avatar
1/2 in nap would be much better.
chrisn is online now   Reply With Quote
Furnace Issue After Sanding Drywall libero99 Drywall & Plaster 8 01-10-2009 10:08 PM
Sanding a drywall ceiling? kcrossley2 Drywall & Plaster 7 01-01-2009 10:44 PM
Sanding drywall primer and a few crack repairs n0c7 Drywall & Plaster 4 06-09-2008 03:31 AM
Sanding drywall after painting... argh! moneymgmt Painting 3 05-06-2008 08:25 AM
Removing drywall dust after sanding? ponchoman1 Painting 6 10-13-2006 08:33 PM
