Sanding My Ceiling - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 03-10-2010, 10:18 AM   #1
Sanding my ceiling
I just bought a house and have the textured ceilings. I want to re due the ceilings to a little more modern looking style. What is the best and easiest way to sand my ceilings.
Newhouse is offline   Reply With Quote
Old 03-10-2010, 10:25 AM   #2
Chaos Engineer
Big N8's Avatar
Rewards Points: 152
PLEASE search. This has been covered a lot.
Big N8 is offline   Reply With Quote
Old 03-10-2010, 10:28 AM   #3
Searched and didn't see anything
Old 03-10-2010, 10:46 AM   #4
Chaos Engineer
Big N8's Avatar
Rewards Points: 152
http://www.diychatroom.com/search.php?searchid=1245318
Old 03-10-2010, 11:06 AM   #5
None of these tell me how to sand down the plaster brush texture. I don't have popcorn. Thanks
Old 03-10-2010, 11:30 AM   #6
1. paintscraper to get the worst of the ridges
2. 60 grit sandpaper
3. skim coat
4. fine grit sandpaper
5. prime with Gardz
6. repaint
I'm doing this right now. If there's a better way, I'd like to know it too.
I've considered 1/4" drywall over the top. eh?
jbowl is offline   Reply With Quote
Old 03-10-2010, 02:13 PM   #7
"Beam me up, Scottie"
Kevin M.'s Avatar
Rewards Points: 150
3. skim coat
5. prime with Gardz
6. repaint
This method is by far the best option if the texture has several coats of paint and is reluctant to come off. Some texture will scrape off like soft butter, other texture is hard to remove with a chisel. It's not worth the hassle to have to gouge and sand the texture. Much easier to rock over with the 1/4".
Kevin
Kevin M. is offline   Reply With Quote
Old 03-11-2010, 08:39 AM   #8
Drywall contractor
Rewards Points: 1,070
Agreed, painted texture will require a lot of scraping, mud over a couple of times, sand, touch-up, sand again..... Easier to put up another layer after scraping the high spots. You can use 1/2". It's cheaper than 1/4" and you can get it in 12' sheets (fewer joints) at you local big box. You can get 12"x1/4" at a drywall supply, but again, costs more than 1/2". IF you're lucky and the ceilings have never been painted (you'll know as soon as you attempt to sand), you can rent a power sander to remove the texture which will also contain the dust.
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Ceiling condensation icemand Building & Construction 1 12-15-2009 06:16 AM
Old ceiling replacement idsp General DIY Discussions 12 07-25-2009 11:48 AM
Advice for installing ceiling fan Ceiling Fan Man Electrical 5 06-02-2009 05:18 PM
Sanding a drywall ceiling? kcrossley2 Drywall & Plaster 7 01-01-2009 10:44 PM
Pot lights in a drop ceiling Howdy Electrical 3 03-14-2008 09:23 PM
