Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Drywall & Plaster
Old 02-22-2010, 11:29 AM   #1
sanding into paper on drywall patch
Hey guys, well i put in a drywall patch and noticed that one side is about 1/16" to high. So when im sanding it sands into the drywall paper somewhat...i was thinking about cutting that small section out and using Gardz to seal it then ill put mud over that...would this be a good solution?
joseph2293 is offline   Reply With Quote
Old 02-22-2010, 11:35 AM   #2
Love for Construction
<*(((><'s Avatar
why not just float out the drywall patch on all sides more, and then you will only be sanding drywall mud and not the paper. I wouldn't recommend cutting out drywall when one can simply put another thin coat to blend in all planes, and then sand accordingly.
That is just my opinion, I'm by no means an expert in drywall finishing but have done plenty myself.
<*(((>< is offline   Reply With Quote
Old 02-22-2010, 01:58 PM   #3
Drywall contractor
Yes, build up the low side to even out the area. If you cut out 1/16" of the drywall, you'll cut through the paper on the face and compromise the integrity. You'd basically have to tape over the area you cut the paper from, putting you right back where you started.....
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 02-22-2010, 08:10 PM   #4
the problem is that ive already started sanding into the paper...so i think at this point i need to cut out the paper...seal and mud...
Old 02-22-2010, 09:13 PM   #5
PHB Construction LLC
Paulie's Avatar
As stated, float the problem area with more mud. Use a 8" or better knife and float the entire area. Then a light sand and your done.
Paulie is offline   Reply With Quote
Old 02-22-2010, 09:26 PM   #6
even if ive sanded some of the paper off?
Old 02-22-2010, 11:16 PM   #7
<*(((><'s Avatar
Doesn't matter. Try and get any loose paper fibers sticking out pulled off, and float over it.
Old 02-23-2010, 04:38 AM   #8
paper hanger and painter
chrisn's Avatar
Apply the Gardz first, then proceed as posted.
Old 02-23-2010, 07:00 AM   #9
remove the patch and eliminat ethe reason one side is sitting high.That wouldbe the best approach in the long-run.
beerdog is offline   Reply With Quote
Old 02-23-2010, 11:07 AM   #10
jlhaslip's Avatar
use a damp sponge instead of sandpaper after you add the next coat of mud on top of the sanded paper.
Go ahead and apply for a variance, those guys at City Hall can use a good laugh.
jlhaslip is offline   Reply With Quote
Old 02-23-2010, 03:50 PM   #11
Use a good quality 150-grit DRYWALL sand paper with a decent hand sander and you can sand drywall paper with little to no fuzzing.
n0c7 is offline   Reply With Quote
Old 02-23-2010, 09:53 PM   #12
awesome ill try it tomorrow and thanks for the help everyone
proper method for paper faced drywall corners rocketdoctor Drywall & Plaster 2 12-06-2009 11:14 AM
Problem Patching Large Drywall Hole FuLLTiLT Drywall & Plaster 5 11-21-2009 10:42 PM
Frustrated by paper along side of drywall J187 Drywall & Plaster 6 04-22-2009 06:29 PM
How To Support A Drywall Patch For Hole In The Wall? dsq Drywall & Plaster 7 02-23-2009 03:48 PM
Painting Drywall Patch markospencer Drywall & Plaster 3 12-30-2008 06:25 AM
