-   -   sanding into paper on drywall patch (http://www.diychatroom.com/f101/sanding-into-paper-drywall-patch-65070/)
joseph2293 02-22-2010 10:29 AM
Hey guys, well i put in a drywall patch and noticed that one side is about 1/16" to high. So when im sanding it sands into the drywall paper somewhat...i was thinking about cutting that small section out and using Gardz to seal it then ill put mud over that...would this be a good solution?
<*(((>< 02-22-2010 10:35 AM
why not just float out the drywall patch on all sides more, and then you will only be sanding drywall mud and not the paper. I wouldn't recommend cutting out drywall when one can simply put another thin coat to blend in all planes, and then sand accordingly.
That is just my opinion, I'm by no means an expert in drywall finishing but have done plenty myself.
bjbatlanta 02-22-2010 12:58 PM
Yes, build up the low side to even out the area. If you cut out 1/16" of the drywall, you'll cut through the paper on the face and compromise the integrity. You'd basically have to tape over the area you cut the paper from, putting you right back where you started.....
joseph2293 02-22-2010 07:10 PM
the problem is that ive already started sanding into the paper...so i think at this point i need to cut out the paper...seal and mud...
Paulie 02-22-2010 08:13 PM
As stated, float the problem area with more mud. Use a 8" or better knife and float the entire area. Then a light sand and your done.
joseph2293 02-22-2010 08:26 PM
even if ive sanded some of the paper off?
<*(((>< 02-22-2010 10:16 PM
Doesn't matter. Try and get any loose paper fibers sticking out pulled off, and float over it.
chrisn 02-23-2010 03:38 AM
Apply the Gardz first, then proceed as posted.:wink:
beerdog 02-23-2010 06:00 AM
remove the patch and eliminat ethe reason one side is sitting high.That wouldbe the best approach in the long-run.
jlhaslip 02-23-2010 10:07 AM
use a damp sponge instead of sandpaper after you add the next coat of mud on top of the sanded paper.
n0c7 02-23-2010 02:50 PM
Use a good quality 150-grit DRYWALL sand paper with a decent hand sander and you can sand drywall paper with little to no fuzzing.
joseph2293 02-23-2010 08:53 PM
awesome ill try it tomorrow and thanks for the help everyone
