Sanding Drywall Primer And A Few Crack Repairs - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 06-08-2008, 04:55 PM   #1
Rewards Points: 518
Sanding drywall primer and a few crack repairs
Just finished priming my walls with Sherwin Williams primer. 95% of everything is good although a few fiberglass seams showed up and cracked in the hallway where there is no airflow and there are a few spots around where I dripped primer.
1) What should I do with the fiberglass cracks? I know the use of this tape is highly debatable but I did use it and I just need to repair a few seams only a few feet long. Should I just sand down the cracked seam and recoat on top or should I cut out the tape and redo the seam with paper tape?
2) Can I use 150grit drywall paper to sand the primer drips?
n0c7 is offline   Reply With Quote
Old 06-08-2008, 08:44 PM   #2
Tired, Cold, and Damp
slickshift's Avatar
If I am understanding you correctly, the fix is to do another coat or two of joint compound over the mesh tape
You either didn't do enough coats, or sanded too far through what you did do
slickshift is offline   Reply With Quote
Old 06-08-2008, 08:56 PM   #3
Drywall and Painting Pro
Sir MixAlot's Avatar
Rewards Points: 908
Or one of the most common mistakes w/ mesh tape. You need to use a setting-type joint compound not a all purpose joint compound.
Sir MixAlot is offline   Reply With Quote
Old 06-08-2008, 10:16 PM   #4
Rewards Points: 518
My first time I used setting-type, but this project I didn't. What are the chances of the rest of the joints cracking over time now?
Old 06-09-2008, 02:31 AM   #5
Rewards Points: 150
100 %
kgphoto is offline   Reply With Quote
New drywall -Sherwin Williams Primer n0c7 Painting 11 12-22-2011 12:27 PM
Drywall ceiling: Water Damage, looking for advice dawho1 Building & Construction 11 09-13-2010 10:05 AM
Toping Compound for texture....before or after drywall primer? yummy mummy Building & Construction 6 05-04-2008 10:57 PM
Sanding Primer Bpawb Painting 4 03-27-2008 03:23 PM
Primer Over Drywall dgoldb1 Painting 16 03-03-2008 04:37 PM
