To Sand Or Not To Sand? - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 02-03-2014, 10:15 PM   #1
Rewards Points: 422
To sand or not to sand?
How do I determine if sanding between coats of compound is needed? I know the pros only sand at the end, but I'm a beginner. How do I know if just a scraping with knife is all that's needed? Thanks.
Jim McC is offline   Reply With Quote
Old 02-04-2014, 03:16 AM   #2
paper hanger and painter
chrisn's Avatar
Rewards Points: 296
Well, if it is not smooth to the touch( rub your hand over it) it needs sanding and it will trust me
chrisn is online now   Reply With Quote
Old 02-04-2014, 03:30 AM   #3
Rewards Points: 13,444
And no amount of primmer and paint is going to fix flaws.
The key is applying thin coats in the first place so there's less sanding needed.
If it takes four coats instead of three while your learning so be it.
Far better, faster and less mess then having to go back and sand it all off.
Most common mistake I see DIY's make is not making the seam wide enough, the wider the seam the easier it is to make it look level.
For the last coat I often use a 12" wide knife with slightly thinned mud.
The whole goal is to fill in the low spots, not build it out away from the wall.
Old 02-04-2014, 06:16 AM   #4
Rewards Points: 5,974
Run your hand over it if there are ridges use your knife to knock them off, any low places will fill with the next coat. Some of the high spots you may need to sand but shouldn't be many. To sand between coats isn't necessary unless your getting a big build up. If this is happening your using too much mud.
Old 02-04-2014, 12:29 PM   #5
Rewards Points: 422
Thanks guys
plaster sand amakarevic Drywall & Plaster 0 08-03-2012 02:53 PM
Paver Joint Sand question: why is my sand so easily washed out? htabbas Concrete, Stone & Masonry 1 06-24-2012 07:04 AM
finishing paver patio - what sand? H.O.P. Landscaping & Lawn Care 2 07-20-2011 02:00 PM
Need Help - Failed Patio in Sand Install lews Landscaping & Lawn Care 5 04-19-2010 06:34 AM
Best Way to Establish Plantings Over Sand flyboy Landscaping & Lawn Care 4 04-07-2009 09:38 AM
