Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Drywall & Plaster
Old 08-29-2009, 10:26 PM   #1
Round tubes behind drywall
I have a quick question. I was adding some new shelving to my garage using the Rubbermaid Fasttrack setup. To add the Fasttrack rails I needed to screw into four studs and add drywall anchors inbetween each stud. I got into the studs fine, but when I was drilling the guides for the drywall anchors I noticed a round pipe (or something similar) just past the drywall.
Basically, I punched through the drywall and stopped the drill but noticed that I hit something round. I couldn't get a good look at it through the 3/8" guide hole so I'm not sure what it is. I noticed this "pipe" at the two (almost) random heights I used to place the Fasttrack rails. I found it odd that I just happended to choose two heights that this exists (56" and 85"). It's also weird that it seems to run left-right (not up-down) and it exists on both the left and right side of the stud. Anyone have any ideas on what it might be? Thanks in advance for any help.
oufan222 is offline   Reply With Quote
Old 08-30-2009, 12:38 AM   #2
Moderator
If black cast iron 1-1/4" pipe, possibly your gas supply. Look outside for meter close-by. Maybe running over to go up to the upstairs fireplace? Look in the garage attic access heading over to the house.
Any plumbing nearby, possibly a vent pipe. Or main electrical service to a sub-panel.
Be safe, G
Old 08-30-2009, 09:16 AM   #3
My house doesn't use gas (no upstairs fire place), although it is two story. I didn't get a good look at the color of the pipes, but they looked white. There is a 1/2 bathroom and a laundry room on the back side of the garage wall in question. However, I find it hard to believe that the two (almost) randomly picked heights I picked have this "pipes" (again I'm not sure that these are pipes, the thing in question was more solid than the drywall and seemed to be pretty sturdy. I guessed it was a pipe because I could slide the drill bit over the top and under the bottom). I don't know alot about construction, but could it be some bracing inbetween the studs? They seem too high to be electrical or water pipers (one is 86" tall).
Again, I greatly appreciate any feedback. Thanks!
Old 08-30-2009, 11:56 AM   #4
Stuck in the 70's
Blondesense's Avatar
You might be an OU fan, but where are you?
Also, how old is the house?
Old 08-30-2009, 01:37 PM   #5
Custom Cabinet Maker
if you own a studfinder that also senses pipe and or electrical try to trace it, see where it leads or at least the direction it heads
skymaster is offline   Reply With Quote
Old 08-30-2009, 06:35 PM   #6
I'm from Oklahoma, but currently live in Alabama. The house is about 4 years old and I've been in it for about 1 year. I have a stud finder (that sucks). I'll try to trace it out this evening to see if that helps. Again, I'm pretty sure I didn't drill into it (I stopped as soon as I felt it). My main concern is that its something that runs through the studs because I put nearly 3" long screws into the studs.
Old 09-05-2009, 05:01 PM   #7
Open the wall and look at the issue, it's just a sheetrock repair versus puncturing something you shouldn't puncture.
Ron
Old 09-08-2009, 04:04 PM   #8
Drywall contractor
Sounds like PVC pipe if it's white. Possibly vent and/or drain lines.....
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old ceiling replacement idsp General Discussion 12 07-25-2009 11:48 AM
Framing for drywall under Spiral staircase clemon03 Drywall & Plaster 6 07-17-2009 04:49 PM
Ecorock (new green drywall product) Sir MixAlot Drywall & Plaster 0 06-20-2009 09:40 AM
Good ways to run pegboard up to drywall? upthemaiden Drywall & Plaster 1 03-09-2009 02:12 PM
Butt Joints at new drywall and existing corner round VistaV Building & Construction 1 02-03-2008 10:36 PM
