Rotozip The Doors And Windows-bits Dont Last - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 02-01-2012, 07:27 AM   #1
Rewards Points: 562
Rotozip the doors and windows-bits dont last
what am I doing wrong? Broke 2 bits in short order rotozipping out doorways.
Is there a way to make this easier? chuck them deeper so dont touch wood so much?
4just1don is offline   Reply With Quote
Old 02-01-2012, 07:45 AM   #2
DIY staff
Rewards Points: 7,174
Move faster---It's easy to over heat the bit---you will learn---and wreck a few bits on the process.
To fast and they snap---to slow and they get hot--
and sometimes there is no explanation--
Old 02-01-2012, 08:16 AM   #3
Rewards Points: 13,274
100% sure your using the right bit?
Are you cutting in a clock wise direction? (starting on the left, go up, at the top moving from left to right)
Old 02-01-2012, 02:14 PM   #4
firehawkmph's Avatar
Rewards Points: 1,822
Also,
Keep a light pressure on the bit, don't over do it. You have to acquire a feel for the bit against the hard surface you are trying to follow. Set the bit just deep enough for the pilot section of the tip to run on the stud.
Mike Hawkins
firehawkmph is offline   Reply With Quote
Old 02-01-2012, 02:45 PM   #5
Jack of all - master none
hyunelan2's Avatar
Rewards Points: 686
Counter-clockwise.
http://www.drywallschool.com/router.htm
hyunelan2 is offline   Reply With Quote
Old 02-01-2012, 03:39 PM   #6
retired union carpenter
Send a message via Yahoo to coupe
http://www.rotozip.com/en-us/Videosa...alSaws101.aspx
it's been a long time, but I remember, if cutting around outside perimeter? cut clockwise. if inside? such as window and door openings cut counter clockwise
as always, just my thoughts
good luck....coupe/Larry
take what helps? ignore the rest.
coupe is offline   Reply With Quote
Old 02-02-2012, 08:58 AM   #7
Rewards Points: 562
bought a 1/4" bit and that seems to help. those 1/8 bits are like small drill bits,,,broken.
Can you chuck them just 1/2 deep plus the bare nose? the less stud shaving you do seems the better. Its not a router after all.
Old 02-02-2012, 09:07 AM   #8
That's the whole reason the tip is there, to act as a guide. Set to low the bit's going to over heat and dig into the wood.
Old 02-02-2012, 09:15 PM   #9
Home Remodeler
Rewards Points: 164
Agree joecaption. If set to high the pilot will also heat up. They do not last very long if not set right.
mikey48 is offline   Reply With Quote
New windows and doors for remodeling Andee77 Building & Construction 2 10-10-2011 03:27 PM
Aligning windows and doors papageek Building & Construction 1 11-04-2010 10:42 AM
Help! Mismatched Trim, Doors, Windows - Paint them All??? Snowy334 Interior Decorating 12 06-30-2009 03:26 PM
Front Home Doors Change or Cut 4 Windows Canis19 Carpentry 13 04-13-2009 07:19 AM
It's hot outside. Keep the exterior doors and windows closed if running the A/C? Taylor Crockett HVAC 3 07-07-2008 06:04 PM
