Rookie Error! - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 01-04-2012, 03:25 AM   #1
Rookie error!
Hey guys wondering how doomed I am. So I put on joint compound in seams and for some reason thought you taped after it was dried and then add your next layers after. How can I fix this? It is only a little compound so can I place tape over dried compound as long as its smoothed out?
Aloha1 is offline   Reply With Quote
Old 01-04-2012, 04:08 AM   #2
Busy DIYer
picflight's Avatar
Rewards Points: 150
Scrape and smooth it out and start over.
picflight is offline   Reply With Quote
Old 01-04-2012, 10:02 AM   #3
Crusty Old Dude
Big Stud's Avatar
Yep, just smooth it out by scraping/ sanding. Then tape over what is left.
You may end up with the tape sticking out more than you would have if you'd done it right the first time, so you may have to feather the mud out further on your finish coats so you won't grind into the tape when you sand it,
All the best to you and yours, Tom
Big Stud is offline   Reply With Quote
Old 01-04-2012, 11:44 AM   #4
retired union carpenter
Send a message via Yahoo to coupe
if it's just a little compound? not kwikset you can probably wash it off with a damp sponge or rag. only dampen not soaked! do it in stages to not get the drywall paper wet and rolling off the gypsum, you only want to dampen the compound. wash some off, let dry, wash more off until it's all off with drywall paper intact then add tape as you apply the mud. forcing the mud into cracks under the tape, keep as smooth as you can.
as always, just my thoughts
good luck....coupe/Larry
take what helps? ignore the rest.
coupe is offline   Reply With Quote
Old 01-04-2012, 04:53 PM   #5
paper hanger and painter
chrisn's Avatar
Rewards Points: 504
I am not a drywall guy but you need to put down a layer of mud FIRST, embed you're tape in there and let it dry and then start mudding, sanding etc.
Old 01-05-2012, 12:23 AM   #6
Busy DIYer
picflight's Avatar
Rewards Points: 150
As a DIY'er I would try to stick with the methods mentioned here
Help with Bryant model 395CA error code 32 cmoe_1999 HVAC 2 02-02-2011 09:42 PM
error code 45 Turtle learner HVAC 2 01-10-2011 04:09 PM
Carrier Error Code 33 russell124 HVAC 4 12-04-2010 07:19 PM
"interface failure/miswire" Vapor error? windowguy Plumbing 0 05-17-2009 04:59 PM
Carrier Furnace Error Code 33 s6skuzy01 HVAC 9 03-09-2009 11:42 AM
