Rigid Foam Under Drywall - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 10-19-2011, 09:00 AM   #1
PoleCat's Avatar
Rewards Points: 1,646
rigid foam under drywall
I am contemplating putting rigid foam under the drywall on my ceiling. Anyone ever done this? It used to be lath and plaster but is just bare joists now. Fiberglass is still going up in the attic.
PoleCat is offline   Reply With Quote
Old 10-19-2011, 05:59 PM   #2
iminaquagmire's Avatar
Rewards Points: 338
There is nothing wrong with doing as you propose so long as you treat that XPS as your vapor barrier and use unfaced insulation in the attic. Unusual, but noting wrong with it. What is your reasoning behind wanting to do this?
iminaquagmire is offline   Reply With Quote
Old 10-19-2011, 06:25 PM   #3
jburd964's Avatar
Rewards Points: 166
The R value of sheet insulation is not that great. Why ate you wanting to do it? If for insulation I save my money.
I'm not a professional., But I did stay at Holiday Inn Express last night.
Gun control isn't about guns, IT'S ABOUT CONTROL.
jburd964 is offline   Reply With Quote
Old 10-19-2011, 08:55 PM   #4
liscenced electrician
Rewards Points: 538
i agree. A little goofy, and would be a lot of work, but if you took the time, it could be a very nice installation. It would gain a tad bit of insulation value over traditional methods because you would be getting some insulation between the drywall and the studs. Whether this would be insignificant or not, i couldn't tell you
jimmy21 is offline   Reply With Quote
Old 10-19-2011, 09:12 PM   #5
PoleCat's Avatar
I don't have a roof at the moment, just a tarp stretched over the rafters and a 3 mil plastic ceiling. Starting to get cool around here. foam on the ceiling would help with noise and temps.
Putting rigid foam on concrete walls...how to lay DriCore in this setup? ChaoticBliss Building & Construction 14 09-12-2012 06:02 PM
Drywall over 1-1.5" rigid foam? michael76 Drywall & Plaster 23 05-22-2011 04:07 AM
Covering rigid foam insulation in furnace area looking4ideas Building & Construction 4 12-30-2009 06:49 AM
Attaching Drywall to 4" of Rigid Foam PerpetuallyRepairing Drywall & Plaster 9 02-19-2009 06:24 PM
Rigid foam sheathing on top of foam insulation? benjamincall HVAC 12 02-04-2009 01:41 AM
