Retexture Painter Walls - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 03-04-2011, 08:12 PM   #1
Retexture painter walls
what steps are needed to retexture my living room walls? They are painted red with latex paint. (step by step) thanks
Miss Fit is offline   Reply With Quote
Old 03-06-2011, 11:26 AM   #2
The walls need to be cleaned, to get any dirt and grime off of it so the new material will adhere better. If you have a high gloss on the existing wall, you can use TSP, to prep the surface. Depending on how dirty the walls are will depend on what you use to clean with. Usually a mild soap and warm water will do the trick, but be sure and rinse. Then after the washing, some people will suggest that you prime the surface to make everything even up for the new texture, thats your call. If there is no texture on the existing wall, then you may want to scuff it with sand paper, (80 grit) to help the new texture stick.
I use beadex taping mud for my orange peel textures. The glue in the mud will help give it tooth.
redmanblackdog is offline   Reply With Quote
Looking for a step by step for framing basement walls/2x4's wrong direction/stairs??? xray328 Remodeling 27 06-19-2011 09:50 PM
Delta-FL on floor and XPS on walls. Should I install the flooring or the walls first? yotaman Remodeling 11 04-19-2011 10:20 AM
No Floating walls where there should be! DIY Master Building & Construction 1 02-23-2011 06:06 AM
Finishing Basement Walls, Inside Perimeter Drains, and Moisture, Oh My BSponz1 Building & Construction 1 02-08-2011 02:20 PM
load bearing walls worriedowner Building & Construction 3 02-02-2011 05:12 PM
