Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Drywall & Plaster
Old 04-28-2011, 12:30 AM   #1
Resilient channel
Hello I'm re doing my bathroom and I'm thinking of using resilient channel to take out some of the waviness of the rafters. I'm installing a pot light and new fan so I need to know what the thinness of the channel is so I know where to set the boxes. The rafters are on 16 in centers. Thanks for the help
Dano199 is offline   Reply With Quote
Old 04-28-2011, 08:37 AM   #2
I make love to my walls
Resilient channel
Half inch
Arey85 is offline   Reply With Quote
Old 04-28-2011, 09:15 AM   #3
Resilient channel
Originally Posted by Arey85
Half inch
Thank you
Old 04-28-2011, 03:01 PM   #4
Resilient channel
Just beware that rc channel isn't going to fix any unevenness other than something really minor. Anything serious should be taken care of with a level and line and scabs or shims.
The Following User Says Thank You to Arey85 For This Useful Post:
Willie T (04-28-2011)
Old 04-28-2011, 11:11 PM   #5
Resilient channel
Well as far as I can tell the most severe spots are no more the a quarter inch do u think that is too much?
Old 04-29-2011, 08:54 AM   #6
Resilient channel
That will be fine. Anytime we use channel on a ceiling we use 5/8" drywall. In my opinion 1/2 drywall will show the sag and as you push with your trowel to tape it it will move with it creating a hollow seam that will show in any light after you paint. 5/8 is a lot stiffer and will have better results.
Old 04-29-2011, 10:13 AM   #7
Resilient channel
Okay thanks alot your help is appreciated
Resilient Channel install around windows and doors Satori Building & Construction 0 02-08-2011 08:02 AM
Auralex resilient channel warnerww Building & Construction 3 02-10-2010 10:12 PM
Resilient Channel For Basement Ceiling Stingray Remodeling 7 02-07-2010 01:14 PM
How-To: cut a channel in concrete? vsheetz Building & Construction 7 01-31-2009 02:21 PM
How to install resilient channel on ceiling Bcoleman6 Building & Construction 1 08-22-2008 03:29 PM
