Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Drywall & Plaster
Old 04-15-2011, 12:44 PM   #1
Residential bullnose corner lines
Hi,
My wife and I are building a new house and just had the sheetrock done. There were a couple concerns on the bullnose corners that I had. My contractor told us that the paint would smooth it out. We went ahead and painted and of course it just made them stand out more. Any opinions if I am being overly picky or do I have a point to push? I have brought them out to see it and they told me it was typical. I don't agree.
liamy is offline   Reply With Quote
Old 04-15-2011, 04:15 PM   #2
Old School
Willie T's Avatar
Today, that's typical. Does that mean it's right? No. It could easliy be flat if they cared to make it so.
Willie T
Old 04-15-2011, 11:27 PM   #3
#1 HAWKEYE FAN
hardwareman's Avatar
I had bullnose corners installed a few months ago and I can assure you they look nothing like that.
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
Old 04-15-2011, 11:44 PM   #4
KemoSabe
loneframer's Avatar
Looks like they went a coat light or were leaning on the knife too hard. If you take a 6" taping knife and lay the blade perpendicular to the surface, from bullnose to bullnose, there should be no gap behind the knife.
Some brands of bullnose bead are worse than others at being concealed. I've seen plastic bullnose that won't hold the mud to a paper thin thickness. Then again, it might have been the mud and not the bullnose.
It's not that it took him an hour to make 100 bucks, it's that it didn't take you 10 hours to save 100 bucks.
loneframer is offline   Reply With Quote
Old 04-16-2011, 08:18 AM   #5
alden5jesus's Avatar
This is serious problem of everyone because of architecture fault, you can use mud to hide the bullnose. Or another option is some paints are available in market which are specially available for hide the bullnose.
_________________
alden5jesus is offline   Reply With Quote
Old 04-16-2011, 04:08 PM   #6
Drywall and Painting Pro
Sir MixAlot's Avatar
Alden, Could you elaborate more on this product or provide a link?
-Paul
Checkout some of
Sir MixAlot is offline   Reply With Quote
How to cut bullnose corner crown molding using compound miter saw darryl0214 Building & Construction 1 03-15-2010 06:58 AM
Insulating wall when running Copper Tube lines to an exposed wall face scubber Plumbing 2 04-13-2009 10:54 AM
Replacing Drywall Corner Beads jodell8964 Building & Construction 2 03-15-2009 07:31 PM
Anybody install or own a CORNER kitchen sink? Also RTA cabs... matermark Kitchen & Bath Remodeling 2 01-24-2009 06:41 PM
one corner of secornd floor room is low 99th_Flyby General Discussion 9 01-12-2009 09:25 PM
