Replacing Wet/damaged Ceiling - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 06-17-2010, 11:44 AM   #1
replacing wet/damaged ceiling
My drywall ceiling was damaged from upper floor plumbing. Damaged ceiling has been cut out. How long should I let the wood dry before starting repair to avoid molding and future problems?
janana2u is offline   Reply With Quote
Old 06-17-2010, 01:40 PM   #2
WaldenL's Avatar
Rewards Points: 268
Until it's dry.
If you cut it out (had it cut out) at the beginning of the repair of the plumbing, then by the time the plumbing is fixed (couple days?) you'll be fine. Obviously remove not only the DW, but any insulation that got soaked. And if there's anything obviously wet, wait longer. But with good air circulation you should be fine rather quickly.
WaldenL is offline   Reply With Quote
Old 06-18-2010, 12:28 PM   #3
Thank you, I really didn't think abut the insulation. Since it's such a small area of damage I'll just replace it!
Old 06-18-2010, 10:49 PM   #4
doing a larger version of this myself. you really need to get under the insulation and make sure it dries if you plan on keeping the drywall. if you want extra protection against mold get a gallon of microban and lightly spray it around the effected areas on a hot day. with the insulation out the microban will dry in 5 minutes or so. obviously you need to be sparing with how much you spray since you're applying a wet product to drywall
racebum is offline   Reply With Quote
Old 06-19-2010, 05:15 AM   #5
Registered User
Rewards Points: 5,516
Use an electric fan to help dry the area faster. A moisture meter would tell whether dry or not but if in doubt, wait a few days before covering.
Be safe, Gary
How do I get power to a new ceiling fan? sestivers Electrical 15 10-10-2016 04:16 PM
pull down ceiling storage crimsonalucard General DIY Discussions 16 02-27-2011 08:39 PM
replacing bathroom ceiling heater... DIYDI100 Electrical 2 01-09-2010 08:34 PM
Replacing drywall ceiling only, not walls shan1616 Drywall & Plaster 10 11-15-2009 03:15 PM
Is my room pre-wired for a ceiling fan? cfrederick02 Electrical 1 04-02-2009 01:08 PM
