Replacing Wall Drywall But Leaving Textured Ceiling - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 08-08-2013, 04:12 PM   #1
Rewards Points: 24
In my basement I've pretty much given up on the drywall on the walls and want to tear it out while leaving the (textured) ceiling in tact. When installing the new sheetrock however how would I go about closing the seam if I already have a finished ceiling? Would I just carefully taper some mud on the new drywall to fill the gap if there is one? Thanks!
knight508 is offline   Reply With Quote
Old 08-08-2013, 04:31 PM   #2
Rewards Points: 14,278
Best thing you can do is get rid of the textured ceiling.
You would have to sand the texture off at least a few inches to get the tape on, trying to get the old texture to match will be a real chore. Most often you end up having to redo the whole ceiling.
Another simple easier way may be to just use crown or cove molding.
Old 08-08-2013, 04:40 PM   #3
Too Short? Cut it Again!
Come on Joe! Depends on what kind of texture you have and whether the ceiling is in decent shape. If it is popcorn, scrape it off. If it is knockdown and you like it? Leave it alone. You probably will not be able to scrape it off.
Drywall, tape and mud the walls. Pick some nice trim to transition between ceiling and wall. Caulk, prime and paint.
The Following User Says Thank You to user1007 For This Useful Post:
knight508 (08-09-2013)
Old 08-08-2013, 04:59 PM   #4
Rewards Points: 512
http://www.trim-tex.com/product_cata...product&id=151
put this along the top of the drywall.
mud it.
tear away the bead
caulk the corner
princelake is offline   Reply With Quote
The Following User Says Thank You to princelake For This Useful Post:
ToolSeeker (08-09-2013)
Old 08-09-2013, 07:19 AM   #5
Rewards Points: 24
I did recently finish putting up some ceiling paint and it does look really fresh so I will be keeping it. The trim idea actually sounds pretty tempting. That fancy trim-tex stuff is a bit confusing, not sure which way it actually goes on. Thanks for the input!
Old 08-09-2013, 04:26 PM   #6
Rewards Points: 512
you glue and staple it to the top of the drywall and skim it out with mud. the tear away strip is so mud doesnt get on the ceiling. once its done pull the strip giving you a finished edge
Taping New Drywall to Existing Textured Ceiling moparmaniac Drywall & Plaster 4 04-07-2011 03:14 PM
Textured Drywall Ceiling Repair TRACKER Drywall & Plaster 7 07-26-2010 05:55 PM
Matching new drywall to old textured drywall pennshaq Drywall & Plaster 1 05-23-2010 09:30 AM
New drywall on wall meets textured ceiling Hall Drywall & Plaster 6 11-24-2009 05:46 PM
Replacing drywall ceiling only, not walls shan1616 Drywall & Plaster 10 11-15-2009 03:15 PM
