Replacing Tape Joint On Stippled Ceiling - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 10-31-2012, 08:38 AM   #1
Question
Replacing tape joint on stippled ceiling
I need some expert input as to the best way to go about replacing a tape joint. The bad joint is along one wall/ceiling, about 10ft long, where the wall meets the stippled ceiling (inside joint) in a 45yr old bathroom that has been repainted 8 (or more) times. Some of the tape has come loose from the wall but most has come loose from the stippled ceiling.
I've done a little drywall taping in the past so I not a complete newbie at this but the stippled ceiling is throwing me a curve. I believe I can remove the old tape without much problem. My question is concerning prepping the surface properly so that the new tape will last another 45 years!
What I need to know is, how much (or how wide) of the stippling do I need to sand smooth in order to bed the new tape? I'm guessing a minimum of 4 inches?
There are several youtube videos on "how to replace bad tape joints" but they all deal with nice smooth walls and/or ceilings, none dealing with replacing tape on stippled surfaces.
This looks pretty much like the stippling on my ceiling:
http://www.all-wall.com/core/media/m...479cd0156e6d55
Thanks in advance for your input...
Rusty Skillz is offline   Reply With Quote
Old 10-31-2012, 07:59 PM   #2
automated tool pro
Rewards Points: 152
you'll need this
http://www.all-wall.com/Categories/D...ple-Brush.html
repair your joint than sand as smooth as possible. I always hand sand any overlapping repair compound until you can not see the transition.....thin down your all purpose, roll it on with a roller and be sure not to put too much on. Once its rolled on smooth, put the stipple brush on a handle, stomp..following the pattern all ready on the ceiling.....now...when you get to where you run out of the rolled on mud, stomp from wet to dry to wet to dry..."a feathering if you will" working your pattern using excess mud as part of the patten in the existing(dry) stipple.
a kind of blending the two areas into one
drywallfinisher is offline   Reply With Quote
Old 10-31-2012, 08:01 PM   #3
automated tool pro
Rewards Points: 152
also when I say you need that brush, ...that is the exact match, and you'll need to get one. This is important
Old 10-31-2012, 09:53 PM   #4
Actually, the pattern of that 11" shag stipple brush is FAR from an exact match of what's on my ceilings.
This is a much, much closer match to what I've got:
http://www.all-wall.com/Categories/D...oinsettia.html
But, back to my original question:
Can anyone offer any insight?
Old 11-01-2012, 09:41 PM   #5
Rewards Points: 5,974
That looks like a 9" roller so I would go just a little farther. If you only go 4" your going to be too thick along the edges.
Replacing Duct Tape Used on HVAC Ducts yarrick19 HVAC 5 06-18-2012 12:29 AM
tape pops in tray ceiling cousindan Drywall & Plaster 7 04-28-2011 12:21 AM
Painting or Replacing Canister Ceiling Lights justagirl Electrical 1 07-14-2008 04:38 AM
Pot lights in a drop ceiling Howdy Electrical 3 03-14-2008 09:23 PM
Replacing 12" ceiling tile with drywall housefixin Remodeling 5 09-09-2007 04:00 PM
