Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Drywall & Plaster
Old 07-21-2011, 02:38 PM   #1
Replacing sections of drywall
Due to a flood I had to cut 3 feet tall sections of drywall all the way around the room. I am not starting to repair work. I have cut the top part(good drywall) so its in the middle of a furring or stud.
I then put up the new drywall to butt up against that. But there are gaps in between the top and bottom sheets. I know it would be best to not have them, but its seems about impossible to do.
If there are gaps in between the sheets should I put some mud in there before I start applying tape? Some sections are like 1/4 inch of a gap.
jburchill is offline   Reply With Quote
Old 07-21-2011, 02:51 PM   #2
Architectural Designer
AGWhitehouse's Avatar
I would squish some compound in before the tape.
Life's too short...so enjoy it!
AGWhitehouse is offline   Reply With Quote
Old 07-21-2011, 06:04 PM   #3
get some durabond easy sand and throw it in the gaps, let it set up then scrape smooth , then proceed as usual. no big deal on the gaps that size or even larger.
oldrivers is offline   Reply With Quote
Old 07-24-2011, 12:51 AM   #4
Moderator
1/8" and under, drying (general purpose) type mud is fine, over 1/8"= setting type mud only-----pp.10, 4.6.8.1,2; http://gypsum.org/pdf/GA-216-2010.html
Gary
Clothes taking longer to dry?
Old 08-03-2011, 02:48 PM   #5
Thanks for the tips.
Another question is that my new section probably won't match up with the old section's texture. I have a few questions regarding this.
1. attempt to match it, and if I mess up think of something else?
2. Is it possible to get rid of the old texture then just apply new texture? If so how would I go about this? Its an orange peel texture that is on there right now. To get rid of it should I skim coat over the entire wall old and new?
Old 08-03-2011, 02:53 PM   #6
I bet you can match it pretty close. Orange peel is easy. Get the homax orange peel spray in a can and practice a bit and you can get it. If you mess up, sand it off. I personally think skimming a whole wall to get rid of texture is tough.
Broughton is offline   Reply With Quote
Old 08-03-2011, 03:32 PM   #7
I might need something more than a can. I am thinking of buying the hopper spray gun since I have another room to do. The section is in a 8x10 room with the bottom half is new drywall.
I have used the can before on a small patch job. And the fumes are really strong. i had to leave the house for a while and air it out.
Old 08-03-2011, 04:54 PM   #8
Drywall contractor
If the boards were run horizontally (likely) why not take out another foot and go to the 4' height. You'll have a factory edge to butt to and won't have to cut a foot off of every replacement piece. Unless you have 9' or 10' ceilings, it's unlikely the board was stood up....
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 08-03-2011, 05:09 PM   #9
boards were vertical. so I cut them to the nearest stud and then put new stuff up.
Old 08-03-2011, 06:42 PM   #10
If you buy a hopper practice more, it puts a lot out and you can overdo it quick. Just spray the whole wall and everything will blend together.
In wall gutter downspout causing mold on drywall. chrispy35 General Discussion 12 05-06-2011 11:35 PM
First-timer drywall install-LONG- Axhammer Drywall & Plaster 8 04-17-2011 10:02 AM
Drywall over Drywall.. NoviceHandyman Drywall & Plaster 6 01-10-2011 09:32 PM
Framing for drywall under Spiral staircase clemon03 Drywall & Plaster 6 07-17-2009 04:49 PM
Framing and Drywall questions haysdb Building & Construction 5 11-04-2005 08:11 AM
