Replacing Plaster With Drywall - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 08-31-2012, 10:56 PM   #1
-_-
Rewards Points: 16
Replacing plaster with drywall
Hi, first post from Boston...
We have a drafty detached garage, built in the 1930s. The walls are plaster over metal lath. There is no electricity or insulation. The back wall was damaged by a car. I removed all of the plaster and lath down to the studs where it was damaged. I have a 3' x 8' piece of sheetrock (1/2") ready to screw into place. I will not put in any insulation.
My only question is, should I put up a piece of polyethlene/plastic/other first, as a vapor barrier?
Thanks in advance!
-_- is offline   Reply With Quote
Old 08-31-2012, 11:05 PM   #2
DIY staff
Rewards Points: 7,174
Not needed in an unheated garage--so add your patch and start taping.
Old 09-01-2012, 12:17 AM   #3
Rewards Points: 12,790
Your going to have to shim out the studs if you expect this to come out even.
oh'mike (09-01-2012)
Old 07-12-2013, 10:44 PM   #4
automated tool pro
Rewards Points: 152
really no need, you wouldnt be making a vapor barrier if it doesnt run from floor to ceiling and wall to wall. Point less
drywallfinisher is offline   Reply With Quote
Converting Plaster to drywall ryanm83 Remodeling 11 03-02-2012 07:02 AM
Options with Plaster and Drywall mjarema414 Drywall & Plaster 6 02-21-2012 09:59 PM
drywall over horsehair plaster w36cowgirl Drywall & Plaster 1 03-23-2010 12:50 PM
drywall mixed with plaster - do I need to tape? Windows Drywall & Plaster 4 03-09-2010 04:02 PM
Old ceiling replacement idsp General DIY Discussions 12 07-25-2009 11:48 AM
