Replacing Paneling With Drywall In A Trailer? - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 04-22-2013, 03:04 PM   #1
replacing paneling with drywall in a trailer?
Hey, I have an 1981 model 12 x 60 trailer that I am completely redoing because it was never kept up and is run down. I want to rip all the paneling out of the house and replace it with Gold Bond 1/2in x 4ft x 8ft drywall panel. I was looking at it on Lowes.com and this particular drywall panel is about 20% lighter than the usual 1/2 in drywall or so lowes.com said. My question is will replacing the paneling that is in my trailer with that drywall make my trailer "too heavy" to possibly later move?
thanks in advance
reesie1 is offline   Reply With Quote
Old 04-22-2013, 04:56 PM   #2
Rewards Points: 13,458
No but it will throw off every piece of trim around all the windows, doors and also mess up how the outlets sit.
What I have done is go over the paneling with 1/4 drywall using drywall adhesive so fewer screws are needed.
You apply the adhesive around the outside edges of the panels (geeting it back about 2" from the outside edges so it does not squeeze out) and in an X pattern in the middle. Press the panel in place and put in a few screws, then roll over it with a hand floor roller to spread out the glue and install the rest of the screws.
A few tips, it needs to be about 1/2 up off the floor on the bottom.
Make sure it's tight to the ceiling.
Remove all the outlet covers and remove the outlet, but leave the wiring on. You pull the outlet out of the box and twist it from top to bottom so it can be pushed back into the box at an angle. This way you can install the sheetrock and end up with the outlets still flush with the face of it when done.
Remove all the trim, including baseboards, window casing.
When cutting to go around the windows you leave it about 3/4 of the width of the casing. EG, of the casing is 3" leave it back about 2" from the jambs.
This way the casing will still fit tight againt the jambs. May just needs some caulking on the back side of the casing where it meets the sheetrock.
Old 04-30-2013, 10:05 AM   #3
Rewards Points: 578
As long as the trailer has a metal frame underneath, with the metal pieces that span from the Ibeams to the edges, it will support it. Mobile homes are made to live in, they can withstand a lot more weight than just some drywall. If you decide to move again, do yourself a favor and hire a professional. That way if there is any problem with moving, they are responsible, not you.
Come and see the progress on my mobile home paradise!!! (NEW PICS ADDED ON 01/26/15!!)
http://www.diychatroom.com/f49/compl...emodel-168570/
TrailerParadise is offline   Reply With Quote
Drywall question. DerWookie Drywall & Plaster 11 11-08-2011 07:08 AM
Replacing damp drywall / plaster in shower Elcontador Drywall & Plaster 2 02-25-2010 05:03 AM
Replacing drywall on an exterior wall MarkHaley Building & Construction 4 02-22-2010 09:42 PM
uneven wood paneling joefromcal Carpentry 6 04-30-2009 09:50 PM
Replacing 12" ceiling tile with drywall housefixin Remodeling 5 09-09-2007 03:00 PM
