Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Drywall
Old 12-27-2008, 04:50 PM   #1
Replacing a few individual tiles in bathroom - chiseled a bit into the drywall
I am trying to remove about 20 individual tiles (not adjacent) from my bathroom and shower to replace them with plain white tiles (currently, these tiles have hideous pictures of different birds on them). I just tried removing one tile so I could get a sense of how laborious this will be. I removed much of the grout and after some chiseling and hammering, got the rest of the 1st tile off. Unfortunately, I went a bit to deep with the chisel and broke into the drywall (there's no hole through the drywall, but I did chip off some of the surface).
I had purchased 2-in-1 tile cement/grout for the project. Can I use this to level off the area of damaged drywall before I replace the tile? Drywall compound? Or what is a reasonable option for me? Again, this project involves only about 20 tiles, and hopefully I'll be able to remove the subsequent ones more cleanly.
Thanks!
Pickngrin is offline   Reply With Quote
Old 12-28-2008, 09:36 AM   #2
If a minor ding, the adhesive will fill the void. For big holes I would fill with drywall compound, mesh tape.
Old 12-28-2008, 09:53 AM   #3
Thanks. I should add (although perhaps it's obvious) that the paper surface of the drywall has been damaged.
Old 12-28-2008, 04:51 PM   #4
Tileman-Manufacturers rep
Are you saying you have drywall in a shower? If so, that is not good. Among other things I would not use drywall compound to repair. Tile adhesive does not like gypsum patching stuff. And you should be using thinset mortar in powder form in spite of the drywall in wet area.
I'd recommend not removing that many tiles. You're liable to cause more damage including breaking tiles you don't intend to remove. Are they that ugly? Birds are nice.
Jaz
Tile 4 You Inc. Troy, MI
KERDI Shower Expert...DITRA Installs
Old 12-28-2008, 07:40 PM   #5
I don't know if I have drywall in the shower. I've only removed one tile, from a wall near the sink, and there was drywall behind. I've got 12 of these hideous tiles in the shower...and yes, they are that ugly ;-o
Jaz
More On This Topic
Tile floors make great surfaces in basement settings. Whatever type tile you chose, you can lay your own tile floor and easily keep it looking good. One of the processes to keeping a good-looking tile floor is sealing the grout. It's an easy step to do... Read More »
Today I’m going to show you how to re-grout the tiles in your bathtub, or your bathroom - you might have them on the wall and what have you. You can see here where it’s just begun to fall out, and it’s just about all gone right here... Read More »
A grouting float is a flat, rectangular piece of metal with a handle on the top that is used to apply grout to a tiled floor. The float is used during one of the final stages of the tiling process and is relatively simple to use. Read More »
Hi! This is Steven from Keilholz Flooring on behalf of Expertvillage.com and in this segment, I am going to show you how to apply a grout and talk about grout a little bit. There are three separate kinds of grout. There is a sandy grout, non-sandy grout... Read More »
Now that we've covered the entire surface and sides with grout, now we're going to start removing the excess grout. You can simply take your hands and wipe away and smooth the grout. Trying to get that smooth and working around. You don't want to dig out... Read More »
2 Drywall boards behind shower tiles? Confused1 Drywall 15 02-15-2010 10:06 AM
Re-tiling a bathtub surround BillyB44 Remodeling 37 05-13-2009 08:05 PM
Replacing a bathroom fan switch cmacjr22 Electrical 4 11-04-2008 07:14 PM
drywalling bathroom / paperless drywall johnny331 Remodeling 7 10-17-2007 09:06 PM
Bathroom Tiling - On top of existing tiles??? moggiex Painting 8 12-13-2006 06:17 AM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
